Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Pilot lite will not stay lite
Propane honeywell furnace. When holding down red button to lite pilot. I wait a minute and when I release button pilot light will NOT stay on.
  • 33 Answers
You need to change the thermocouple on the unit.
First check to see if the flame is hitting the thermocouple when the flame is on when you hold down the button. If it is then remove the the thermocouple and replace with the same size. You should be able to pick one up at your local hardware store.
If when you replace the thermocouple the flame does not stay lit still you may have a bad gas valve.
Hope this helps and please rate this!
Posted on Dec 08, 2008
What do I need to do to lite my heater after a summer rest?
How to Light a Furnace Pilot Light Here, we'll explain the basic steps for re-lighting the pilot light of a gas furnace.
#1: Locate the Instructions Label on Your Furnace
Every furnace should have a label on it that tells you how to light a furnace. Sometimes, however, the printing may be small or the furnace area may be dark. In these cases, the label may be difficult to read. Keeping the following instructions near your furnace or in another safe spot where they can be located easily will make the task much easier.
#2: Find Pilot Light and Components
Near the bottom of your furnace is a switch that normally says "Pilot," "On" and "Off." Find this switch and turn it to the "Off" position. Wait at least five minutes. This is important because it gives the gas time to dissipate, which is necessary to avoid possibly starting a fire. While you are waiting, take note of the location of the reset button, which should be near the dial you just turned to "Off."
#3: Re-Light the Pilot Light
Once the gas has had time to dissipate, turn the knob to "Pilot." Then, hold down the "Reset" button and bring the flame of a long lighter close to the pilot light opening. This should light the furnace pilot light. Once you are sure the pilot light is on, release your pressure on the reset button.
Sometimes, seeing a job bein
Oct 28, 2017 | Heating & Cooling
Per landlord, need to light pilot
You would smell the gas, so you're probably ok. Lighting the pilot is not too tough, first you have to get the cover off the furnace. Inside you will see pipes and parts. Hopefully on the cover, inside or out, or somewhere inside the furnace will be instructions.
If not, find a knob that has 'pilot', 'off' and 'run' or something like that. It will probably be in 'run'.
Usually, you have to push the knob down and turn it to get it to the 'pilot' spot. When you do, have something to lite the pilot, which will be inside the furnace more, near the burner. The burner looks like a gas stove or oven burner. The pilot place will be at the end of a small tube.
With the button held down, wave something burning around the burner area. especially at what may be the pilot. The pilot doesn't put out much gas, so don't worry about things blowing up.
Once the pilot has lit, hold the button down for a while, at least a minute. Then you should be able to release the button and the pilot should stay on. If it doesn't, you need a serviceman to come. Let the landlord know the pilot would not stay lit.
If the pilot stays lit, move the knob to 'run' or such, and the furnace should lite, if the thermostat is set higher than room temp. If it has been off, and the room is cool, it should lite.
If the furnace doesn't come on, let the landlord know.
Most landlords have service people for this, it was my job for a long time. Lighting pilots was a common chore for me. If you can, have the landlord send one out to show you how to do it.
As you see, it's not all tough, but it's not all easy, either.
Nov 29, 2013 | Heating & Cooling
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Gas wall heater won't light
You need to bled the line longer and when you get lited hold down for a good minute.When the gas gave out ,there could trash in the line.I would take the line off and blow gas through it undtil you can smell it.
Mar 12, 2009 | Heating & Cooling
Pilot ligting instructions
many of the newer furnaces don't have a standing pilot. look to see if you have a gas valve with a knob on top that says off pilot and on. look to see if a tube the size of a pencil comes out of the valve and goes down by one of the burners, look to see if there is a little gold piece of metal tubing protruding down to the opening of the larger tube . that is where you place the match. i prefer to use a grill lighter. safer and positive flame. turn knob to off wait 5 minutes for any gas to disipate. be sure your incoming gas valves are all open . usually at the meter and one at the furnace. usually the handle is in line with the pipe when open. from the off position, turn the knob on the furnace gas valve to pilot position and push down on it as you turn. this lets gas flow to the pilot tube by the burner where you have you flame starter lit and waiting. once pilot lights hold down on button for 3 minutes or less. longer is better to be sure the thermocouple senses flame . then gently release the downward pressure and the pilot should stay lit and you gently turn knob to on. if pilot goes out you may have a bad thermocouple. be especially careful if its lp or propane as that gas does not disipate like natural gas and can virtually lay on the floor till ignited. also consider having the heat exchanger checked by a pro with a carbon monoxide detector. they do crack after a few years and can be deadly when they do. good luck
Nov 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Heating & Cooling Logo
353 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
