Question about Lexmark X1240 All-In-One InkJet Printer
I can't find out where to plug in the cord to the printer.
We moved and my sister took the plug out of the printer. Now I don't know where it is supposed to be plugged in at. Please help! Thanks
Back lefthand side looks more like a square than a usb
Posted on Dec 15, 2008
I moved, now I can't find where to plug in the power cord? HELP
Actually, the power cord plugs into the printer's power adapter. Please see image below:
If you lost the power adapter, please contact Lexmark Technical Support Center for assistance.
I hope this helps.
Jan 15, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
I hope this helps.
Jan 15, 2012 | Lexmark X4690 Wireless InkJet Printer
I have a 6100 All-in One, and I am getting a message saying Error, and says that the right Cartridge is incorrect, but I have used the cartridge for over 3 months, I don't know what to do next.
Try this approach instead:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert both cartridges firmly. Close the printer cover and check for any errors.
  7. Try to print a document again to verify that the problem is fixed.
Jan 12, 2012 | Lexmark X3650 Printer
How do I reset displaylanguage to english HP C6180
You can do a reset on your printer.Unplug the power cord of the printer.Press and hold the # and 6 buttons together and then plug the power cord back into the outlet.Keep holding the 2 buttons until the display goes blank or RESET is displayed.If the printer automatically turns off, turn on the printer.The printer should start up and you will be able to select language code.
Oct 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
I need another cord that plugs from the printer to the computer, what is that cord called? Also, do you know where I can find one? Thanks
You just need a standard USB cable, available at any store that sells computers and printers or printer supplies. If you don't know what you're looking for, just tell them you want to hook up your printer and they'll show you what you need.
Apr 26, 2011 | Lexmark X8350 All-In-One InkJet Printer
I had a paper jam and I took it out easily, no paper left in it at all, but now it wont print anything and keeps having a paper jam error. what now>
There may be some small piece of paper left please check that
otherwise try this
Unplug the power cord from the back of the printer while the printer is ON
press and hold Start copy black and Cancel button at the same time while holding them plug in the power cord and once the printer turns On then release the buttons
If still error then try to move the carriage manually from left to right and right to left
Apr 20, 2011 | HP DeskJet F4280 All In One Printer InkJet
Paper jam msg on printer, carriage jam msg on Imac. Carriage locked to right under 'hood'. Removed all paper, disassembled cover, took out cartridges, remove and reinstalled print head. Followed all...
Hi Good day!! try this turn off the printer pull out the power cord and usb cable, check the pathway of the print head maybe there is something the block in your printer that may cause your print head to not move perfectly. if all clean move the print head to the center, now re plug the power cord and turn back on your printer, reply if still the same.
Dec 02, 2010 | HP Photosmart Premium C309A All-In-One...
The paper was pulled out to clear the paper jam opposite the standard path of travel. Ever since I can not clear the error Carriage Jam. HELP
Dont worry,
Now open the front access door and manually move the cradle left to right 10-15 times gently (cradle carries printheads in it which moves left to right in order to print.
>>Clean the rollers with the lint free cloth and lttle bit of water.
>>Do a pwr drain(take out the powr cord and press and hold the power button for 20 sec and release it and plug in the cord back.
>>Do a partial reset take out the powr cord and press and hold the # and the 3 button and holding both plug in back the power cord.Release the buttons once the printer powers on.
>>If still its not working ..Do a semifull reset take out the powr cord and press and hold the # and the 6 this time button and holding both plug in back the power cord.Release the buttons once the printer powers on.
>>If doesnt work......call Hp and they will replace the printer for you.
Let me Know.
Best wishes,
Suvrajit
Oct 03, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Making funny clicking noise and hour glass showing that it is processing won't go away
As a follow-on to solution 2 (thanks for the post BTW), I found the problem is indeed the light bar, but rather than breaking into the printer to move and lube the light bar, I found success by simply shaking the printer with the left side down, to move the light bar along it's track to the left. (the shaking motion is sort of like getting ketchup out of a bottle).
This worked better for me than dismantling the printer with a special screw driver and seemingly needing to break the panel to get to the third screw. Hopefully this helps.
Oct 11, 2007 | HP PSC 2510 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
