Question about Microsoft Windows 98 for PC
Unable to log on
After password is entered the following m,essage appears " the group policy client sewrvice failed to log on" " access denied" the only option is to click the "ok" button, after clicking the "ok" button, the computer automaticly logs off.
I am currently using another computer to write this message.
My college final is due 12/09/08.
Please help, I need all my info
  • allhousemail Dec 09, 2008
    Am running Vista, I called dell. Problem is fixed. Started puter in safe mode then restored. Thank you
    Scholar:
  • 135 Answers
Is the PC in question yours ?
this is more than likely a security related issue since the server you are attempting to log on to is Server 2003 and u still on 98... server 2003 and 98 dont like each other... see it as microsoft trying to bully you into upgrading your software...
and since you are not the network admin, ( i assume ) you wont be able to fix it, since you dont the rights, easiest solution :
remove the hard drive from the win98 PC and put it in another PC as a secondary or slave drive.. you will be able to access the data on the 98 hard drive via my computer..
if this sounds too daring or you have no idea what im talking about you need to urgently get hold of someone with some basic pc hardware knowledge and ask for help. While what ive suggested here is what i call "basic" ive also been working with PCs for 20+ years... so im not judging you :)
Posted on Dec 09, 2008
Turns on goes to user screen when i put password in it says group policy client service failed access denied
Sounds like you'll need to make another user account, then try to remove whatever rights the problem account has. You could try going to microsofts help page and type the statement exactly, include error codes if there are any, or, try this, http://windowshelp.microsoft.com/Windows/en-US/Help/769495bf-035c-4764-a538-c9b05c22001e1033.mspx
Hope you get it fixed, Grim
Aug 19, 2015 | Computers & Internet
Tip
Fix Windows 7 Error ?Windows is Not Genuine? Error code 0×80070005
Those users running genuine version of Windows 7 provided with their hardware platform reported that immediately after log on they were presented with following error message. “Windows is not genuine. Your computer might not be running a counterfeit copy of Windows. 0×80070005.”
Some other symptoms of associated with this issue are,
The computer desktop background is black, and you receive the following error message on the bottom right corner of the screen:
“This copy of Windows is not genuine”
You receive the following error message when you view the System Properties: (Control Panel / System and Security / System)
“You must activate today. Activate Windows now”
If you try to use slmgr.vbs /dlv to view the licensing status, you receive the following message:
Error: 0×80070005 Access denied: the requested action requires elevated privileges
Microsoft is fully aware of this issue and provided following explanation for the issue,
There is a lack of permissions in the registry key HKU\S-1-5-20. The Network Service account must have full control and read permissions over that registry key.
This situation may be the result of applying a Plug and Play Group Policy object (GPO).
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B).
Method A: Disable the Plug and Play Policy
1. Determine the source of the policy . To do this, follow these steps:
a. On the client experiencing the Activation error, run the Resultant Set of Policy wizard by clicking Start, Run and entering rsop.msc as the command.
b. Visit the following location:
Computer Configuration / Policies / Windows Settings /Security Settings / System Services /
If the Plug and Play service is configured through a Group Policy setting, you see it here with settings other than Not Defined. Additionally, you can see which Group Policy is applying this setting.
2. Disable the Group Policy settings and force the Group Policy to be reapplied.
a. Edit the Group Policy that is identified in Step 1 and change the setting to “Not Defined.” Or, follow the section below to add the required permissions for the Network Service account.
b. Force the Group Policy setting to reapply: gpupdate /force (a restart of the client is sometimes required)
Method B: Edit the permissions of the Group Policy:
1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
2. Click the Edit Security button, and then click the Advanced button.
3. In the Advanced Security Settings for Plug and Play window click Add and then add the SERVICE account. Then, click OK
4. Select the following permissions in the Allow section and then click OK:
Query template, Query status, Enumerate dependents, Interrogate, User-defined control, Read permissions
Note: The Previous rights are the minimum required permissions.
5. Run gpupdate /force after you apply the previous permissions to the Group Policy setting.
6. Verify that the appropriate permissions are applied with the following command:
sc sdshow plugplay
The following are the rights applied to the Plug and Play service in SDDL:
D:(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;SY)
(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)
(A;;CCLCSWLOCRRC;;;IU)
(A;;CCLCSWLOCRRC;;;SU)
S:(AU;FA;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;WD)
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to “SU” (SDDL_SERVICE – Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
SU: Service Logon User
Note: If there are no GPO’s in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
1. On the computer that is out of tolerance, start Registry Editor.
2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions…
3. If the NETWORK SERVICE is not present, click Add…
4. In Enter the object names to select type Network Service and then click Check Names and OK.
5. Select the NETWORK SERVICE and Grant Full Control and Read permissions.
6. Restart the computer.
7. After the restart, the system may require activation. Complete the activation.
on Jul 15, 2010 | Computers & Internet
I cant logon to my user, the message is The Group Policy Client Service failed the logon. Access is denied
I think that it is possible because of the client server isn't running. Try contacting your administrator.
Jul 23, 2014 | Microsoft Windows 7 Home Premium 64BIT...
INSPIRON 1545 WON'T LOG IN MESSGE READS 'THE GROUP POLICY CLIENT SERVICE FAILED THE LOG ON ACCESS IS DENIED' RUNNING WINDOWS 7 HOME PREMIUM
Are you able to get to the desktop in safe mode?
Repeatedly press F8 on startup and choose to boot to safe mode in the options window.
Mar 28, 2012 | Dell Inspiron 1545
I have a message - The Group Policy Client service failed the login. Access is denied. How do I access my laptop?
Here is the official Microsoft fix to that, follow it very carefully
Oct 26, 2010 | Acer Aspire 3680 Laptop
Logging on
This is about all you can do.
  1. Reboot into Safe Mode and created another User Account with Administration privileges.
  2. when you get into Windows using the newly created account.
  3. Delete the user Account that was having the error.
  4. Create a new account for your child.
Please rate this solution.
Jan 16, 2009 | Acer Aspire 3680 Notebook
Cannot log on to laptop
What is your OS ?? If it is windows xp and you didnt setup admin password when your sysrem was instaled you can try restart your laptop, When will start rebooting wait till you see second boot screen and start pressing F8 when you will see emergancy menu click to save mode, Log on as Admin (not your name) and when system willl started go to: control panel,user accounts,logon as admin,go to your profile(account with your name) and press remove password. then restart your computer. Your password will be gone.
Dec 27, 2008 | Computers & Internet
HP LaserJet 5100 network printer
In admin mode, you need to add the client to printer permissions
You must be logged on as an administrator or a member of the Administrators group.
To assign this user right, follow these steps:
1. Click Start, click Run, type gpedit.msc, and then click OK.
2. Click Computer Configuration, click Windows Settings, click Security Settings, click Local Policies, and then click User Rights Assignment.
Dec 15, 2007 | HP LaserJet 5100tn Printer
Microsoft Windows 98 for PC Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
