Video prong broke off and stuck in TV video input
When I pull off the TV/VIDEO plugs (yellow white red) the yellow prong broke off and is now stuck in the outlet. The same thing happened in the front of the TV. How do i remove the broke prong??
  • Anonymous Jan 26, 2009
    Same Exact thing here
AlmostBob
  • 550 Answers
SOURCE: broken av inputs
I use a screw extractor,
a tapered threaded tool that binds on the inside of bolts et al, you wind it inside the broken end and pull gently.
where the item is a press fit and very small, needle nose pliers may provide sufficient grip.
Posted on Sep 01, 2008
  • 275 Answers
SOURCE: Video Input
Are you sure that the source is generating a video signal? It is extremely rare for both front and rear Video Input sockets to fail simultaneoisly. from your description, i would suspect the cable connecting the Viseo out of your DVD player / Video Game than the Video Input ports of the TV. If you have another cable, just try again with that. Or, try using the Red to red cable into the Yellow port, using one end at the DVD player and the other at the TV Video Input. If there is image, then it is confirmed that the cable is faulty, and you can get a replacement cable for a few bucks at any Video store.
Posted on Mar 21, 2007
ladywinn
  • 5138 Answers
SOURCE: How to access video input (red, white, yellow)?
I was wondering have you fixed this yet?
Posted on Jan 21, 2008
kakee
  • 1269 Answers
SOURCE: Screen goes black and resets during HD shows
Are you on Cable service or Direct TV. Have you tried the analog signal? HDTV ready monitor can use a standard analog signal. Most HDTV ready tv's have analog tuners built into them, meaning you can use standard cable/over the air signals on them. They will not be high definition. You can use the analog hookup by hooking it to the coaxial antenna hookup, or, if you have a cable box, it may have a set of audio/video outs (the red-white-yellow rca plugs on the back) that you can use to hook up for a slightly sharper picture.
Posted on Aug 31, 2008
  • 3 Answers
SOURCE: Stuck Video prong!!!!!!!
well, if we're talking about the same TV, you can get an alan wrench to fit the screws on the back panel.
now, are you talking about the video in, or the ANT in?
Posted on Jan 28, 2009
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
How to hook up tv to onkyo txds575 receiver...
Red and white plug into the component audio inputs (red is right and white is left) and yellow plugs into component video input
Jan 27, 2013 | Onkyo TX-DS575 Receiver
I can hear the tv but no picture.. i remove the red, yellow, and white cord from the back of the tv to dust...pls help.. Apex tv brand
Hi! Welcome to Fixya!
If you are unable to view video on your television set, the issue may be that the TV's video input selection does not match.
The TV input source must match how the equipment for example DVD is connected to the TV.
* Plug the RCA cables(red,yellow,white cord) to the designated ports.
* Grab your Apex TV remote and attempt to cycle through the video inputs by hitting the "Input" button at the top of the remote multiple times.
* If you have used a DVD player or similar external device recently, you may have neglected to switch the video input back to the one assigned to your TV programming.
* Devices such as DVD players often reside on the AV 1 or AV 2 video input, and failure to switch back off of one of these will result in a dark, soundless screen when attempting to view cable or satellite television.
* Cycle through the inputs until you land on your cable/satellite input once more, which should result in an immediate restoration of picture and sound.
* If it does not, approach your Apex TV and look over the A/V cable connections. The A/V cable has two sets of prongs, one on either of its ends. Each prong is either red, yellow and white, and plugs into corresponding A/V ports on the back of the Apex TV and the back of your cable or satellite box. Make sure the ports and prongs are color-corresponding and have not been switched up.
Thank you for using FixYa. Keep me posted. :
Mar 12, 2011 | Televison & Video
When ever i plug in my video and audio cable the red white and yellow ones, into the back of my Toshiba 26CV100U TV i don't get the picture i only get the sound what should i do ?
The Red, White and Yellow (AV) cable is for composite video and stereo audio. The yellow cable is the video part of this, the red and white are the audio --
3 possible solutions for you:
1. Make sure you match up the color of the plugs with the sockets on your tv.
2. Make sure you're not using the Red, Green, Blue (RGB) input on your tv which uses similar plugs, but has a different color coding.
3. Make sure your tv input is set to the AV input. This is often controlled by the "TV/Video" button on your remote, and the AV input is often called "Video 2" or "3" depending on the model.
Feb 28, 2011 | Toshiba Televison & Video
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
My coaxial broke off the back of my tv, I was told that you can still hook it up without that by using the yellow, white and red cord. My question is which spots do these color ends go into to make this...
You don't give much information. Coax from what broke off? TV antenna, or from something like a DVD or Dish or DIRECTV? Depending on where it came from, you might be able to use ylw, white, and red. If wherever the coax comes from has those outputs, simply use a ylw, red, and white cable and run to an available input on your TV. Having a VCR and DVD player already hooked up makes no difference whatsoever, as long as you have more inputs available. If you are out of inputs on your TV, you can buy a "video switch box" which allows you to use only one input on your TV, which keeps you from switching the TV input back and forth, by pushing a button on the "video switch box" to choose DVD, VCR, Dish, or whatever. (Yellow is video, red and white are left and right sound). Or, you might have red, blue, and green out put on your device. If you do, run them (using a cable with the same color scheme) to the appropriate input on your TV. BUT: you can get a new coax cable with connectors on each end for a couple dollars most anywhere, that would be easiest.
Feb 02, 2018 | Televison & Video
How do i, connect or plug in, my Playstation 2 into a viewsonic N2635w. and yes the Viewsonic is a TV.
Standard Audio Video or Component. Input on the back of TV. It should be for all intensive purposes "plug n play" Hope this helps. If you need more help, post a comment and I'll help some more
Jul 07, 2009 | ViewSonic N2635w 26 in. LCD Television
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
Wii has no color
Are you connecting you Wii to a progressive scan TV input (2 for audio (red)(white), 3 for video (yellow)(blue)(red)?
It's possible you have the red audio and red video inputs switched.
If you have the regular AV-Cable (2 for audio (red)(white), 1 for video (yellow)), and your TV has 5 inputs (progressive), look for the 3 inputs (2 for audio (red)(white), 1 for video (yellow). If it doesn't, connect it to a VCR and run the Wii through the VCR input.
Dec 25, 2008 | Nintendo Wii Console
Connecting my DVD player to my widescreen TV
PRETTY SIMPLE, CONNECT YOUR 3 PRONG CABLE FROM VIDEO AND AUDIO OUTPUT ON THE COLBY DVD TO THE INPUT VIDEO/AUDIO ON THE TV.SWITCH AV INPUT ON THE TV TO VIDEO 1.
Dec 15, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
873 people viewed this question
Top Televison & Video Experts
