I need to know what size central heat and air unit i need for my house
  • 6ikes Dec 14, 2008
    i didnt know there was a reply until today sorry i have no old central heating and air unit there s no vents or ducs, we'll put those in ourselves but we live in hobart oklahoma and our house is 2 story of 2300 sq feet all together we were thinking of 2 seperate units one down one up all electric no gas and as far as the heat will be electric also and we're flexible on what kind
  • 85 Answers
Absolutely, can you give me the following info?
Do you have ducting? If so how many vents? How many return vents, and what size? How many square feet do you have to heat and cool? Are you replacing an old unit? If so whats the old units model number and make? Are you buying the Heat Pump, gas furnace, electric furnace, or dual fuel, or Air conditioner?
Thanks a lot of questions, but extremely important in sizing your home.
Posted on Dec 08, 2008
  • Armando Bernal Dec 11, 2008
    Never mind, I don't need to be waisting my time if your not even considerate enough to even respond.
What size central a/c,heater do I need to cool-heat a 2400 sq/ft house in west Texas
You haven't included enough information to give you an accurate number. Things to consider are:
- R value of attic and wall insulation
-cubic footage of the living area
-are the windows single double or triple paned... low E ?
-how many hours of direct sun?
-how many points of return air do you have?
Its better to over size your system than to undersize.
One more thing to consider.... heat rises, cooled air falls and if you want to run your ducting under the house? insulate the crawlspace walls.
Nov 19, 2013 | Heating & Cooling
Need the motor size on a carrier 38SQ940311
Carriers usually have a 1/4 HP condenser fan motor.
Jul 19, 2012 | Carrier Heating & Cooling
Eddfx24fa2 model # on furnace of central air unit in my basement I am trying to calculate wattage of this central air unit On compressor outside: 220 volts, 60 amps??? Does amps sound correct? amps x...
It is a two ton system. and without doing a heat load Calculation and not knowing the heat load It would not be anything but a guess. But if everything is working properly and the system is clean and with good duct work, than it should be big enough for the size of your house.
Jun 06, 2011 | Airtemp B6Y12F2A Air Conditioner
We have a central air unit that is serial number BTR736B100A0 and model number 314127T18. I need to know the size of the unit. What square footage of house is this for?
This is a 3 ton unit. I go tthat from the 36 in your serial number. 36 means 36,000 btu's which equals 3 tons which cools a home 1,500 square feet to 1,700. If this help please rate me and do a testimonial.
May 23, 2011 | GE Heating & Cooling
HOW DO I WIRE A HEAT STRIP IN MY HEIL CENTRAL AIR CONDITIONER ?
Do you have power to the unit for the new heat strips? what size strips do you have? 10kw-15kw.. ect.
If you had heat strips previously, then i will just need to know the size and application.
Dec 15, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
When we turn on the central air there is a strong burning smell...like burnt toast but way stronger. IS it safe to remian in the house?
Is your central air furnace or electric heat. Electric furnace sometimes have electric strip sequencer stick in the closed positions leaving on one strip of the electric heat. Get a service tech as soon as possible to check this out. Any smells from a central unit need to be teken care of promptly. TURN OFF unit you have it checked for your safety. Rus
Jun 28, 2009 | Coleman Heating & Cooling
How do I find the filter on a lennox G8Q3904 furnace?
If you don't have a filter "rack" installed then you have to remove the blower housing door. Usually the filter is there if it is not located in the house where the return air supply is. Some units have a filter in what is called a return air filter grill. If there isn't a filter already installed in the unit then you will have to measure the inside dimensions and then use one that is similar in size. It's not imperative that you use the exact same size. You just want to cover the opening of the unit. If you don't have central air conditioning, then it's not necessary to use a filter.
Mar 30, 2009 | Heating & Cooling
I have an old 1985-86 coleman central heat and air need manual
The filter is located before the blower if your Coleman is in a mobile home it will be in the door facing. If it is a standard ac/heat application and a regular residential furnace the blower in the cabinet on down flow (ducts in floor) will be above it and possible in the duct connecting in the top. If its the other way (ducts in ceiling) it could be right under the blower. Either of these could have a filter cabinet on the furnace or could have a filter grille at the end of the return air duct (where the air is sucked in).
Mar 10, 2009 | Coleman Heating & Cooling
Vulcan CX Central ducted heating. RE: Following a power outage the control panel does not respond, I have checked the pilot light and it is still on. I need to know how to reset the time and get it to...
The control panel gets its power from the central heating unit's power point. Try turning the power off outside at the powerpoint next to the ducted heating unit and try turning it on again after a few seconds, see if it resets
Jul 06, 2008 | Heating & Cooling
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
