More info needed
Hi there--you responded to a question I posted on this site regarding my Dell computer. Basically, the disc drive is no longer recognized by the computer at all. It's not listed anywhere and the whole D drive is not anywhere to be found.
Your suggestion was to right click on My Computer and click "eject". Where in My Computer? I've gone to My Computer and looked for that option under CD/DVD and any options like it.
Can you tell me more?
Thanks much!
  • emerymfca Jan 16, 2009
    Our DVD drive no longer works. When I go to "My Computer," it is not even listed anymore. I think it was the "D" drive. Any advice on how to get it recognized and working would be greatly appreciated!
Try to download the driver for your disk driver some times dell computers dump drivers for no reason I use to have a dell and I had to get drivers alot for the same thing hopes this helps
Posted on Dec 11, 2008
When i press control f11 to restore my computer it does'nt respond do anybody have any other option for me?
Did this computer come with a recovery disc(s) or is F11 your only option for recovery?
If you didn't get a disc then you probably have a recovery partition on your hard drive. If this is the case there is a good chance your hard drive is failing or has failed. This would also wreck your recovery partition. Your best bet would be to replace the hard drive and order a recovery disc set from Dell. They cost anywhere from $15-40 and you can order them on their site or call them.
Dec 26, 2012 | Dell OPTIPLEX 745 PC Desktop
Just wanting a diagram and some help regarding WHY my cruise no longer works ! My mechanic needs a diagram for the cruise control. He says that it is not the switch, but is it not the most common...
Hi sstar1960, Please note that one of our Experts, toneman2121, posted a Clarification Request asking you to provide the year of your car just 20 minutes after you posted your original question. Responding to these sort of requests for additional info is imperative if you are to receive a solution. I hope that you will respond with your car's year, so that our Experts may help you resolve this issue. Thank you for using FixYa. Please feel free to contact our Support Team directly at: http://www.fixya.com/contact
Jun 04, 2010 | Oldsmobile LSS Cars & Trucks
I want to pull info off a hard drive & put onto a disc.
If your new computer doesn't accommodate the drive then you will need a three and a half inch hard drive enclosure to put the hard dive in from the other computer.
You will have to look at the drive to work out which type enclosure you will need.
It will either be a SATA connection like this >>>>
Or a IDE/ATA connection like this >>>>
If you compare the connections on these examples you will one has plastic connections and one has brass pin connections.
As soon as you know which type of drive you have you can then proceed to purchase an enclosure.
When you have got the correct enclosure all you have to do is install the drive and connect it your new computer.
You will be able to access the drive, copy your data and use the drive as an external hard drive.
Regards.
Sep 22, 2009 | Dell Dimension E310 PC Desktop
Dell won't look at my laptop any longer because they say it needs more memory,but the computer man in town say that this laptop will not handle more memory.Now what ?
Post the model number of your laptop here and how much memory is installed at this time and i'll tell you if can be further upgraded.
Regards.
Aug 03, 2009 | Dell Computers & Internet
Dell D830 DVD RW Drive (e:) Not responding
Using the service tag from your computer, go to http://support.dell.com and check to make sure you have the latest firmware and driver for your CD Drive.
Is the GTA2 made for PC, or are you trying to port a PS2/PS3 game to work on PC?
Mar 15, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
DVD drive will not respond to any form of media inserted into the drive. My computer is a Dell inspiron 530s. I'm running Windows XP
did you install the driver of your motherboard?if so,you need to download and install the dvd decoder for your media from the manufacturers site. if you cannot play even cd, the problem is in your dvd drive.if your dvd drive comes with a driver then you have to install it.actually there are more solutions to your problem try follow the solution I've mention first,and if its still not working post your reply and i will give you another solution.
Feb 22, 2009 | Dell Inspiron 530s Desktop Computer
Trying to restore Dell Inspiron 1501 to factory settings.
don't hit ctrl, f11 instead hit F8 and then go into Dell Factory Image Restore, that will wipe, format and reinstall all the factory software that's stored on the Recovery Drive (usually the D: drive) good luck.
http://virusremoval.vpweb.com
New York
Jan 27, 2009 | Dell Inspiron 1501 Notebook
Re: dell laptop
Hi
Any Dell XP disc will reinstall the system back to XP. You will need to download the system board drivers from the Dell Support site after you have installed XP.
Borrow a any Dell disc from someone, it will work
Dec 03, 2008 | Dell Latitude D600 Notebook
Flash drive no longer can support readyboost
Hi
I need a bit more info to properly respond to your query regarding Microsoft ReadyBoast feature in Windows Vista and 2008 Server.
1. Has this particular Flash disk ever work?
2. How much free space is on the flash disk?
3. Is the Flash disk connect to an onboad port or a cabled port?
4. If this is a new device, does it support USB 2.0? What is the transfer spec from the manufacture?
Regards
Mike
Mar 22, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
