Toshiba Equium a110-233 Won't turn on
I have got this Laptop and for some reason it will no longer turn on I thought maybe the battery had gone so pluged in the power supply, the light to say its on mains power lights up blue but still when I press the power button nothing it doesnt even spike. I have looked to see if there is a reset but can't find one, nor can i find the cmos battery, does anyone know what might be the problem and how to over come it.
  • clarelunnon Dec 09, 2008
    same
  • Anonymous Apr 30, 2009
    same problem
Why won't my Toshiba Equium P200D-139 laptop stay on
It sounds like either the battery needs replacing or you need a new power supply.
If it works while plugged into the power and only shuts off when unplugged then it's the battery otherwise it's the power supply.
Thread Equium P200D 139 battery seems to be dead
Jul 28, 2015 | Toshiba Computers & Internet
Won't turn power on
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Toshiba Satellite L555 AC Adapter 90Watt 19V 4.74A
Jan 05, 2013 | Lifetime Toshiba Satellite L555S7008...
L655 Satellite won't start up.
Replacement Toshiba Satellite L655 AC Adapter 65Watt 19V 3.42A
Replacement Toshiba Satellite L655 AC Adapter 75Watt 19V 3.95A
Dec 17, 2012 | Toshiba Satellite Pro A210-EZ2202X...
Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
hold ctrl+alt and press the up or down key to change the screen to its original position
May 05, 2010 | Toshiba Equium 100 PC Desktop
My toshiba equium A110-233 malfunction
try removing the battery and power adapter for a few minutes then plug in just the power adapter and boot up. then shut all down and put in battery and adapter and see if that helps.
Jan 02, 2010 | Toshiba Computers & Internet
How do i restore a toshiba L350 laptop to factory
Hello, Bob.
Use the Recovery CDs that came with the system. If you no longer have them, order them through Toshiba. Here's their website:
http://www.toshiba.com/tai/
Hope this helps.
Oct 21, 2009 | Toshiba Computers & Internet
Restoring factory settings
You can restore your laptop using a regular windows cd, formatting the disk and reinstalling the OS again. After that all the devices which the drivers are not included on the windows CD like for example; network, sound, video, you can download them from the manufacturer website and complete in this way the process to restore your laptop to zero.
Nov 15, 2008 | Toshiba Equium 3150M PC Desktop
Computers & Internet Logo
640 people viewed this question
David Payne
David Payne
