Question about Fisher and Paykel DEGX1 Electric Dryer
Heating element doesn't heat
The heating element will not get hot. I've checked both elements and there is resistance and there is a voltage between the posts on the element and ground. I've also disassembled the sensor wires and looked over the circuit board for any burns. As this is an $800 dryer, I really could use an idea what to look for.
  • 1 more comment
  • Jesse Hobson Mar 10, 2007
    ok i figured it out. I removed the casing around the lint collector and found that the humidity sensor was packed very tightly with lint. I removed the lint and ran it twice. It's worked fine since then.
  • Anonymous Jul 19, 2008
    Where is this humidity sensor located? Thank you in advance!
  • Anonymous Mar 30, 2014
    Dryer is not powering up
  • 641 Answers
Well done !
Posted on Aug 04, 2007
Bingo!!!
Posted on Oct 08, 2008
I had the same problem. Solved it in the same way. Thanks!
Posted on Nov 21, 2007
My garrison heater does not heat at all. The control panel works but no heat comes out. What do I do?
If you know how to use a multi-meter or volt-meter, open the unit and check for voltage where the heating element connects. You can this with the element connected or not connected... which ever is easier. Unplug the unit before you remove the cover from the heater or disconnect the element. If you don't know how to use a multi-meter, it's time to get one from Harbor Freight and get on YouTube to learn how to use it. Plug the unit in. If you don't have voltage to the element connection, check any and all fuses. If you have power at the heating element connection, check the heating element for resistance with it disconnected. See YouTube on how to measure resistance. Don't worry about how much resistance. If there is none... it's a bad element and you can order one.
Good luck,
Jan 21, 2018 | Heating & Cooling
We can't get our hot tub to heat. The heater light comes on but the heater still won't heat.
heating elements are resistors that get hot
one end will have 115 volts but the other end should be considerable less because the resistance of the heating element drops the voltage
if you used a ohm meter you should be reading a resistance of 500-1000 ohms for a good heater element but with your readings , there will be no resistance so the element is faulty
Apr 06, 2017 | Element Water Heaters
I have an older Jaccuzzi hot tub w a balboa h136 board and single button topside control. The hot tub will not heat. The LED lights up on low speed and goes off on high speed. I just replaced the heater a...
You have voltage across the element but no heat....
Disconnect one element connection and do a resistance/continuity test. Or use a clamp to measure running current.
Feb 13, 2015 | Jacuzzi Home
Dryer runs but doesn't heat I have a Roper RES7646KQ2, l have replaced the following parts: 1-Thermostat 2-Thermal cut off kit which replaces (hi limit and Thermostat 3-Heating Element Still...
If I remember correctly, this model has a switch on the motor which activates both legs
of the 220 to allow the heating element to come on. There is a wiring diagram under the
lid of the dryer and should show this. Hope this helps.
Jun 21, 2011 | Dryers
Oven only heats to 150 f regardless what the
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 16, 2010 | Jenn-Air JES8850AAS Electric Kitchen Range
Kenmore Model 110.96585200 No heat!
You probably have a bad thermal cut-off . This is the small thermostat , located at the top of the element housing . This " thermostat " should read infinate resistance ( no resistance ) . You can put the 2 wires togather , and see if heat comes on . pt # 3399848 . Both thermostats , should read 0 resistance . They are normally closed . The thermal cut-off , will not reset itself , if open . This is a safety t-stat , for when dryer gets too hot , and will have to be replaced .
Nov 11, 2009 | Kenmore Dryers
No hot water
If the water does not heat, then you have to troubleshoot to find the problem. With a voltmeter determine if 240VAC is actually getting to the water heater. Take care here - a defective circuit breaker can give a false 240 volt reading - check for the 240 volts across the upper element (i.e. when the 240 volts has a live load on it, not just an open circuit test).
Also, remember, the upper element has priority over the lower element, and if the water is cold, the upper element will try to turn on and this locks out the lower element (only one element is allowed to heat at any given time). The lower element comes on ONLY after the upper thermostat is satisfied. Therefore if the upper heating element is burned out you will never get any hot water. If you suspect this, TURN OFF THE POWER TO THE HEATER and take a resistance check of the upper element.
Nov 15, 2008 | Water Heaters
Hot Water Heater Trouble
(1)Have the unit check for electric voltage to the element
If voltage going to the element and no heating
(2)Your heating element may be defective.
(3) Have it replace by qualified personel
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water isn't heating up and not drying
Check with a multi-meter for voltage (220/115v) on heating element's tags. If you can read this voltage on tags - you should replace the heating element In case you can't read voltage on its tags, disconnect one of the wires from its tag (you should unplug first your machine's power cable!) and test for element's resistance - If you can read its resistance, you should replace the thermostat. In case of no resistance - you should replace element and thermostat Good luck!
Mar 12, 2007 | Zanussi 18 in. ZSF4123 Slim-Line...
Fisher and Paykel DEGX1 Electric Dryer Logo
178 people viewed this question
Top Fisher and Paykel Dryers Experts
Craig Butler
Craig Butler
jimorris77
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
