Yesterday i was cleanning my hp compaq when i finished it doesn't work
How did you clean by hand ? make sure all of you your drives power and data leads have secure connections make sure the CPU central processing unit has a dust free secure seating
did you move any wiring data or power leads
Test all leads power and data that attach from motherboard to your hard drive,IDE,SATA
make sure your computer ram modules have secure seatings with no dust in sockets
Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
SOURCE: manual
From
this page on the HP support site
you can download the reference manual and other documentation.
Don't forget to rate this solution once you've tried it !
SOURCE: i format my hp compaq d530 cmt,i need some
You should be able to download a compatible driver from this URL. Post back if you have errors or issues with reinstalling.
SOURCE: Sound/Ethernet/VGA drivers
Kindly check out the following link http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135.....it has all the specifics i.e. Win XP,Win Vista...etc.....
SOURCE: I WANT TO DOWNLOAD HP
you can easily download the setup from the following sites
forums11.itrc.hp.com/service/forums/questionanswer.do?threadId
h18000.www1.hp.com/products/quickspecs/11632.../1163
h30499.www3.hp.com/t5/...PCs...HP-d530-CM
ptf.com/vga/vga+hp+compaq+d530+cmt
www.topshareware.com/...hp-compaq-d530-cmt.../downloads
www.user-guides.co.uk/download/hp/hpcompaq/hp-compaq-d530-cmt-manual-placa-
download and install it on your device,it will work just be fine
You can download the drivers from the Compaq/HP WEB
support/download page. Make sure you select your model computer and the XP or
Vista Windows version of the drivers you require and install them. Click on
this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Did you use a vacuum? What is a -> 'Cable of alimentation', and does brache = break?
