Question about Car Audio & Video
Need to change the time on my clock on a factory radio/cd player on a 2004 chevrolet blazer, can you tell me how?
    Problem Solver:
  • 17 Answers
Most GM factory head units have two small buttons on the face of the unit that are labeled "H" and "M", and you need to press them with the tip of a pin or other similar item.
Press the "H" button for changing the Hours, and the "M" button for minutes
Posted on Dec 09, 2008
How do you set the clock in a 2004 mustang radio cd player factory radio
There should be a menu button on the face. Press and scroll through the options until you get to time. Then use the arrow buttons to change hours and then minutes. Since you did not specify the radio model number, this is the best that can be done with the information at hand.
Sep 07, 2015 | Ford Cars & Trucks
I need someone to help me for Clock setting. My clock way off 30 mins. I would like to set them up to the right time. 2004 Chevrolet Trail Blazer. Can you please help me?- appreciated for your support
In the lower lefthand corner of your radio unit there are two small buttons, one is marked H (or HR) and the other M (or MN). These are pressed to change the Hours and Minutes of the clock display.
Aug 26, 2011 | 2004 Chevrolet TrailBlazer
The CD player in my factory stereo has a CD stuck inside of it. We know that the radio is programmed for this VIN # only. Can I unplug the stereo and fix the CD player and then plug it back in without...
Try disconnecting the battery for a few seconds and try to eject the cd, if this don't work you can take the cd player to the dealer ship and they can send it to be repaired
Aug 05, 2011 | 2004 Chevrolet Monte Carlo
Can I change My Radio casset in my blazer 2004 or it will cause problem to my computer or engen
Hi:
changing out your factory radio should not effect your computer or engine system. Some things to consider are that if by chance, your blazer has onstar, then there are functions of that system that wont work well, unless you buy a module to interface aftermaket radios to it.
Oct 05, 2010 | 2000 Chevrolet Blazer
2004 chevy tahoe cd goes into radio and display
Yeah you need a new CD player common on those trucks but be careful the RDS radios must be programmed if get a used factory radio
Nov 20, 2017 | 2004 Chevrolet Tahoe
Which is the fuse for the car cd player and clock?
remove all fuses one by one and check wich one is blown if blown replace it and see if radio and clock works
Nov 22, 2009 | 2001 Chevrolet Blazer
I can't change the time of the clock on the Hyundai 50645P CD player/AM FM clock. There is no information in the Sante Fe manual. Any advice?
Try this, put the key in the ignition and let it be on the first turn right marked "ACC" or you can turn off the stereo and you will notice that only the Digital Clock screen will show. Turn the Volume/Audio/Sel knob and press on the "DISP" button simultaneously for about 4 seconds then release the "DISP" button. The digital clock will start blinking, and then use the Tune/Seek arrows pointing up and down to change the time. If the hour digit is blinking change the hour and after you have changed it press "DISP" then the minute digit will start to blink change it using the arrows, when you are done press "DISP" again or leave the clock for between 4 to 8 seconds the clock will start working normally.
I hope this works for you.
Aquinas
Apr 19, 2009 | 2004 Hyundai Santa Fe
Change the clock
To set clock . You need ignition switch in the on position .Now look at the radio's display on the right side there two round spots marked H and M. With a ball point pen press H to set the hour and again do the same thing with the M to set the minutes. Now clock is set
Apr 17, 2009 | 2004 Jeep Wrangler
2004 Chevy Trailblazer radio and CD player works, but no sound
if you have installed a new cd player in there then the propblem could be that your speaker wires and either touching each other or grounding them selfs out.. pull of the cd player and check to make sure all the speaker wires are covered properly and no bare wires are exposed.. if you still have a factory cd player in it then you will probably need to take it to a dealership to have it checked out..
Feb 18, 2009 | 2001 Chevrolet Suburban
Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Nov 15, 2007 | Emerson Smartset Clock Radio
Car Audio & Video Logo
60 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
