This problem may occur due to both hardware and software issues
to rectify the cause go to bios setup pressing f2,del etc and wait for a while if ur pc restarts in bios then problem is due to hard ware and if not then then problem is releted to software.
solution releted to hardware
1>reassemble the pc and before assembling again while installing motherboard in cabinet first use spunch or thick papar to avoide the problems due to shorting
2>apply heat sink compound on the surface of micro processor and check weather the processor fan is attached to system properly.
3>after doing this things if still problem continues then purchase debugg card and install it on ur motherboards pci slot then switch on the pc u will find error code on debugg card note the error and find its meaning on user manuall.
2>solution related to software
press f8 while pc reboots select safe mode option then go to control pannel remove all newly installed software
after doing this scan ur pc for virus
