Denon DCM-280 5-Disc CD Changer Logo
Posted on Jul 07, 2012
Denon DCM-280 not reading all CD-R, originals and some CD-R reads fine without skipping. What to do?
Optic has been replaced, a KSS-213CL to a KSS-213C Capacitors of the power supply to the optic chip has been replaced
5 Related Answers
Anonymous
  • 807 Answers
  • Posted on Mar 14, 2008
SOURCE: New laserunit won't work
You seem confident enought to take it apart, have you tried cleaning the runners that the laser runs backward and forward on.
Some times they collect dirt/dust and the laser can't move smoothly so it jerks and skips.
Anonymous
  • Posted on Feb 16, 2009
SOURCE: Denon DCM 5000 error code
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Anonymous
  • 6784 Answers
  • Posted on May 18, 2009
SOURCE: Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
Anonymous
  • 3 Answers
  • Posted on Aug 03, 2009
SOURCE: Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Anonymous
  • Posted on Oct 26, 2009
SOURCE: cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
How do you get to the lens for cleaning
There is special disk for sale for cleaning lenses. Otherwise you will have to take apart your changer to clean lenses. If you have some experience and tools - you'll be fine.
1helpful
Where is the mp3 plug in for a denon DCM-280
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Denon-DCM-280-CD-Players-review-manual/id/363ci871/t/1-2/
It's capable of playing MP3's right out of the box. See page 18.
1helpful
4helpful
Increasing static and complete sound loss
hello you mean buzzing,humming cause is a high missing broken ground and it needs service by electronic shop............make shure is not missing any wire that must be connected or undervlotage working............saludos
1helpful
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Need to open it manually
hello try to disconnect from ac wait a minute and reconnect it push on and push open see what happens,now you may open the unit its a kind of hard getting inside the laser system dont touch the laser and dont look at it...when is working....tyou may need some knowledge saludos
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
