Back to:
Tags:
Sco RGA365 Gas Cook Top Kitchen Hood
Kitchen aid cook top gas. iginator consstantly... (by 2 users)
posted by strutzburger on Mar 12, 2007
I have a four burner gas cook top with electric snap start. I was washing the cook top and one burner started snapping with out the burner turned on. It wont stop. I tried turning off stove breaker and turning back on still the same problem? Any ideas. My cook top is made by kitchen aid and I never had this problem before. It is really bad.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by ahuja, posted on Dec 01, 2007
I have the same problem with Frigidaire professional series gas cooktop. This happened right after the cleaning. I tried to use the hair dryer method, but have not worked. Any other thoughts?
Best Solution
posted on Mar 12, 2007
FixYa! (100)
catriver
Rank:Guru Guru
Rating: 94%, 2650 votes
strutz, you probabley got one of the valve switches wet when cleaning. It could of shorted out or it might be just wet. Pull the control knobs off the burners and take a hair dryer and go over the valves slowly. See if it stops the clicking. If not you will probabley have to change out one of the switches. Im not coming up with anything with the RGA365 model number. Try the above posted first...Catriver..post back.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on kitchen aid cook top gas. iginator consstantly firing with knoob off:
I don't want to Accept this solution
Can you Help with these Kitchen Hoods problems?
Kitchen Hoods
cooker hood fan was making whirring sound for last 1-2...
Kitchen Hoods
I bought a Kenmore Elite Advantium 120 tech model from...
Kitchen Hoods
i live in a flat with no chimney and i would like to...
Kitchen Hoods
how do you remove the grills that protect the extraction...
Kitchen Hoods
i bought a baumann tukan 80 cooker hood off ebay but i...
Loading problems.
Repair Service
Find Kitchen Hood Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
