Question about Canon PIXMA MP600 all-In-One InkJet Printer
The mini 260 printer do not print
I just installed the canon mini 260 printer, everything looks right, but there is not sign of any printing when the paper comes out
  • rncoral Dec 11, 2008
    Thank you very much gremlin 11. It works!
    Scholar:
  • 78 Answers
Rncoral,
go into the preferences of the printer, under the maintenance tab you will see head clean. clean the head and do a nozzle check. If you get nothing after two or three head claens, then the head is failing and will require replacing.
Gremlin11
Posted on Dec 11, 2008
I have a canon pixma mini 260 i replaced the ink cartridge this morning and its allowing me to pick my photos and its printing but the photos are coming out blank?
its a common problem after getting refilled cartridge....
please insert a new catridge and try again.........
sure u can solve this problem.......
thank u .........
Jul 22, 2011 | Canon PIXMA mini260 InkJet Photo Printer
I have a Canon Pixma 260 photo printer which I have not used for 2-3 years. Everything seems to be working EXCEPT when I try to print, nothing appears on the photo paper! I just bought a new ink cartridge...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 28, 2011 | Canon PIXMA mini260 InkJet Photo Printer
We have giant company & having CANON LBP 2900.Whenever i am going give print it,s not printed .message shown ready to print but error occuring please help
try checking the printer if it is installed properly, by going to the printers and faxes folder, right click lbp2900 and check its properties, verify if the port used is correct. check printer if it is online and also the usb connection. if everything is ok, try replacing the usb cable. if after replacing the cable and the printer still doesn't print, uninstall it and remove the connection. Restart the computer and begin installation, do not connect the printer unless the system prompt you to do so. Run test print after the installation.
Jun 22, 2010 | Canon LASER SHOT LBP-2900 Printer
Canon mini 260
If you figure this out PLEASE let me know! I'm having the same problem & can't find an answer anywhere! I've cleaned everything from the header to the rollers, I've done alignments, and NOTHING is working! THanks ~ Jamie Hippytrip@aol.com
Sep 19, 2009 | Canon PIXMA® mini260 InkJet Photo Printer
Printer problem
Pretend you need to replace the ink again. Open the MP600 so the carriage moves to the center (just like your going to replace the ink). Than power off the printer. Remove the cartridges & look very closely at the copper contacts. (Sometime when you remove the protective tape some of the sticky tape leaves a residue. If you can not see anything than get some house hold alcohol & a couple cotton swabs. Dampen the cotton & wipe the copper contacts on the ink cartridge (Not the bottom) & the copper contacts inside the carriage. Let everything dry. Alcohol does not leave a residue. Return the ink cartridges (good tight fit). Close the lid & power on the printer. Print a test page.
Left click once on the start button, slide up to & click on Printers and Faxes. The Printer and Faxes window will open. Right click once on your MP600 & left click on properties. Click Print a test page. If the colors did not come out correctly than run an alignment through your printer software & try again.
Everything I mention above is based on the idea that your printer was running just fine but you ran out of ink.
Please correct me if this is not the case.
Good Luck!
If I can be of more service, just ask.
Mike
Apr 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
I have a pixma mini 260 printer. i was just wondering if i can pull pictures from my computer and print it that way rather than off a camera?
Have you connected the printer to the USB on your pc, installing the windows software and tried printing to it like you would a regular printer?? it should work...
Apr 03, 2008 | Office Equipment & Supplies
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Canon ip1600 wont work
make sure an select the ip1600 from your print chooser when the print menu comes up. If you have used another printer with your mini, it my be "defaulted" to the old one.
Sep 02, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
81 people viewed this question
old marine
old marine
