Question about Electrolux Vacuums
The Vacuum canister is working but the tip did not havesuction power. Should I change it? Where can I finf the repair shp in my vicinity. My area is Ravenna, Ohio 44266. My Vacuum cleaner is about 10 years old similar to Ultralux 2000.
  • 903 Answers
Try checking for blockages first, turn the foot of the vaccuum over and check the inlet tube, there may be a little flap that needs to be pulled forward for you to see if there is a blockage.
Posted on Dec 08, 2008
How do you repair the hose if it is flattened in the mid way ?
Due largely to the electrical wiring, vacuum hoses are very difficulty to repair. If the hose is flattened/damaged, the wiring may have been damaged and construes a shock hazard at the least. Trying to repair the hose increases the possibility of wiring damage.
However, you can try getting a lenth of PVC or similar pipe that is a slightly smaller diameter than the hose. Insert one end into the canister end of hose and gently push it to the flattened area. Slowly and gently use it to work the flattened area out.
I don't know if this will work, but it's worth a try. If it doesn't, a new hose is needed.
Sep 07, 2010 | Electrolux Lux 5500 Canister Vacuum
I'm looking for an electrolux oxygen repair manual
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Mar 29, 2010 | Kenmore 23513 Progressive Bagged Canister...
Hoover S3590 Bagged Canister Vacuum power issue
The problem you are describing sounds like to be electrical in the cord reel. I would take it to a repair shop for estimate, sometimes these can be repaired rather than replaced. If under warranty, I would definitely take it in.
Mar 21, 2009 | Hoover S3590 Bagged Canister Vacuum
No power when its turned on
There was a (common cause) power arc during the swap (while running the vacuum).
The fuse located under the grey clipped-on plate of the canister is blown. The fuse is soldered-on the board and would need to be changed (board or fuse). Not "user friendly" zone. Warranty? Smart if they designed a breaker button instead of a fuse here...
Mar 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
Feb 16, 2009 | Kenmore Vacuums
Rainbow e series Canister vacuum
Posted by tinyrose on Jun 10, 2008
I am looking for a repair manual for this vacuum. Just stopped working and will not turn on. Can you tell me where to get a manual? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The best way to get a Rainbow E Series owner’s manual is to contact the Rainbow website and or factory and give them the model and serial # for the item and you may be able to download the manual from the website or the might have to mail it out to your home USPS. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below: Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Miele white star canister vacuum - won't turn on, but isn't clogged
Miele S251i Plus Bagged Canister Vacuum
Miele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light. 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST). 1-800-328-9430
Apr 18, 2008 | Miele S251i Plus Bagged Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
35 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
