Back to:
Tags:
Vestax IF180 Input Fader Car Equalizer
What's the best setting for the EQ controls - My...
By Rachel007 - usenet poster
What's the best setting for the EQ controls - My buddy says the best setting is to boost the lows and the highs and cut the mids?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 06, 2007
Not Rated (0)
Swez1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Many beginners have misconceptions about how to use EQ processing tools. The goal is to use the boost features as little as possible and cut adjacent sliders as needed to obtain the desired effects. As Reynolds stated, start the tweaking with control bands set to "flat". (Zero cut/boost)
The human ear is most sensitive to the midrange audio band. (300-1,500 Hz.)We may wind up attenuating this band range a few dB if needed.
Above and below that, some may need a few dB of boost to compensate for hearing, speaker performance and ambience of the music we are listening to.
In most cases, it is best to avoid using more than +6dB on any given band of EQ settings. This is especially true in the 100 Hz. and lower ranges. This often leads to excessive distortion in amplifiers, (Clipping) and can be hard on smaller format speakers as well.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on What's the best setting for the EQ controls - My buddy says the best setting is to boost the lows ....:
I don't want to Accept this solution
Solution #2
posted on Aug 08, 2005
Not Rated (0)
Reynolds
Rating: 0%, 0 votes
While many people do like to boost the low and high frequencies, this setting may not sound the best in your system. The best way to determine the most appropriate EQ settings is trial and error. Your speakers and the inside of your car both come into play, as well as the type of music you typically listen to.
Start with all the sliders set flat, so that the EQ is not affecting your sound. Then make minor adjustments to the appropriate frequencies that are missing or are too strong. For example, if your vocals are not coming through clearly, boost some of the middle frequencies a little.
Or maybe the vocals aren't clear because the highs are too piercing. In this case, attenuate some of the higher frequency bands a little. And instead of boosting the low frequencies all the way up (and we've all been tempted), try bringing them up just a little bit, while lowering the mids and highs a touch ? you'll get more effective gain out of your system that way (and you won't fry your speakers). The great thing about having an equalizer is that you can change the sound of your music quickly and easily to match your mood.
Thank You!
Can you Help with these Car Equalizers problems?
Car Equalizers
reset TO perform a soft reset, press the reset hole in the...
Car Equalizers
hey seems you can't see my solution at all heres the part...
Car Equalizers
can someone please help me, i am trying to setup my...
Car Equalizers
just bought car eq not hooked up please tell me where the...
Car Equalizers
I have a Alpine AI-NET ERA G320 DPS. If I buy a alpine...
Loading problems.
Repair Service
Find Car Equalizer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
