Question about Sharp LC-26GA5U 26 in. HD-Ready LCD Television
Sharp LCD 26 constant "STATIC NOISE" WHY!?
Our one year old sharp lcd (model# LC26GA5U)has just started popping all the while it is on. it sounds like static electricity.. the picture quality is fine. of course i didn't take out the circuit city warranty as i never expected a problem at 13 months. any advice or opinions on what this might be? thank you! hal
3 Suggested Answers
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
  • 176 Answers
SOURCE: We have a sharp lcd tv. it is 2.5 years old. The
the lcd tv hhave somethig like a bulb and after a period of use that bulb must be changed. take the tv on service. the service man wil see what is the problem most accurate.
Posted on Feb 14, 2010
  • 4721 Answers
SOURCE: My TV Sharp 26 SB1 LCD PBS channel breaks up
Do any other OTA channels break up on this TV? Look through your setup options menu for a TV reset (memory or restore default or a similar command) . Do the reset and exit the menus (save the action on most TVs); then return and rescan the OTA channels.
On a different brand of TV this worked. The channel had broken up for several weeks; the reset was used when the channel finally became totally corrupted (no video on one sub-channel, no audio on the other).
Some tuners need a stronger signal to be stable; you may need an amplifier on your antenna.
I hope one of these ideas helps.
Posted on May 01, 2010
0 characters
1 Points
How do I replace a broken circuit board on a Sharp LC-60E78UN TV?
You can either remove the power supply and check and replace caps and most likely the transformer (pop sound). Or a replacement can be found on eBay, amazon, etc... One model TV can have numerous diff power supply models from revisions and improvements. If you replace the board make sure you look match serial numbers on board to the new board. The back of the TV will come off very easy. Lay TV face down on a flat surface(making sure nothing is touching the LCD) remove screws. (Make sure cable coax slides free, some have a retainer but to remove) once the back is off the layout should be so simple, you should have no problem identifying parts.
Sep 12, 2015 | Sharp AQUOS LC-60E78UN 60" LCD TV...
Get screw thread size & length for lc26Ga5u
Which screws are you talking about? My 26" Sharp uses metric screws for everything but there are several different sizes. If you're looking at the wall mount screws, find the metric screw that will thread easily by hand and limit the length to about 1" long. (Check Lowes or home depot in the hardware section.)
Dec 31, 2014 | Sharp Flat Panel Televisions
There is a constant whining or ringing sound even when muted or viewing DVDs. It is a Sharp LC-42D62U. What might cause this?
Electrical interference inside of the Television is the culprit here!
CRT and old Televisions used to produce this sound.
I would contact Sharp concerning this, since LCD's do not usually make this sound. You could get a warranty replacement for the television since there seems to be a malfunctioning part.
Hope this helped!
Jun 03, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Sharp lc-26dv12u about 2years old. All of a sudden
Sounds like the Main mother board is the problem. When the processor chip overheats, the programming information passing through the chip slows down. Most cases, replacing the main mother board will fix the problem.
Dec 29, 2009 | Sharp LC-26DV12U 26 in. LCD TV/DVD Combo
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Speakers making a constant poping noise.
this could be due to some static  please get your electrical point checked up 1st  is your tv hooked to watch television thru RF or AV please have the interlink cables if this does not help get back with more details
Oct 15, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC 37 D6U
That popping noise means the silicon grease underneath the audio ic has melted and is shorting the audio. This is unfortunately a design flaw by sharp. To fix the problem, you'd have to disassemble the entire TV and clean off the melted residue off of the AV Board and replace it with a new Sharp Heat Insulation Pad. Its a pretty difficult job, I suggest calling your local Sharp authorized service center to fix that for you.
Apr 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-26GA5U 26 in. HD-Ready LCD Television Logo
Top Sharp Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a Sharp Flat Panel Television Expert? Answer questions, earn points and help others
