Question about T-Mobile Dash Smartphone
Dash is typing like regular phone, how do I get full key board settings back?
For texting pres alt then space bar...select the ABC and regular full keyboard is used..
Posted on Dec 09, 2008
I can't sending text msg from my phone....when i send i get error :-general memory full..closed some application and try again.. and i also forget my lock code so i can;t restore factory...
its a common problem, the phone memory gets filled up quickly, 1st you have to format the phone memory then this problem can be solved but make sure to change the message storage memory to memory card instead of phone memory, otherwise this problem will occur again.
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
rate my answer too
Jan 11, 2011 | Nokia N81
I need lock code for restoring original factory settings for nokia n81 2GB mobile
If you want to restore factory settings here is the solution :
good luck .
rate if useful please !
Oct 01, 2009 | Nokia N81
My nokia 3230 autometically reboot's it self
try a soft format of the phone(*#7370#)... if problem persists u'll hv to go the extreme method a full format! and here's how;
1.Back up all relevant data.
2.Press *,3and the green key down at once!
3. While dose keys r stil pressed down, power ur phone off.
4. Power d phone again while those keys r stil pressed down.
Now u wld hv reformatted ur phone back to original settings, reconfigure ur settings n enjoy!
May 01, 2009 | Nokia 3230
My phone is frozen
Pop out the battery and sim and wait 10 seconds and put them back in..
here is 2 useful tips:
How to Hard Reset a T-Mobile Dash/ HTCS620:
1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
How to Hard Reset a T-Mobile Dash and HTCS620 without the operating system:
Turn the handheld off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
Feb 17, 2009 | T-Mobile Dash Smartphone
I can't dial out.
The Phone application on the BlackBerry smartphone automatically converts phone numbers that include letters into the associated numbers.
To key a phone number that contains letters, press the right Shift key or the Alt key and type. The letters appear on your screen, but the BlackBerry smartphone translates them into the appropriate numbers when the phone call is made.
For example, to call 1-877-BLK-BERR (1-877-255-2377) from your BlackBerry smartphone,
  1. Open the Phone application.
  2. Type 1877.
  3. Press and hold the Alt or right Shift key and type BLKBERR.
  4. Display the menu and select Call 1877BLKBERR or press Enter. When the phone number is dialed, the letters are converted to numbers on the screen.
  5. To end the phone call, hold down the Escape key.
To return to the Home screen from any other screen, press the End key.
To lock the device, set a password. Hold the * key.
To unlock the device, press the * key. Click Unlock. Type your password.
To lock the keyboard, hold the * key.
To unlock the keyboard, press the * key
To switch the input language, hold the Alt key and press the Enter key. Continue to hold the Alt key and select a language. Release the Alt key to switch to that language.
To switch back to your original input language, press the Alt key + the Enter key.
I hope this helps
Please remember to rate this solution.
Sep 21, 2008 | RIM BlackBerry Pearl 8100
My key board on my dash
http://www.cellphone-repair-shop.com/proddetail.php?prod=HTCDashKeyboard&review=true
You will need to replace this part. Sometimes when keys get pressed to hard in you pocket a layer on this part gets stuck.
Jul 14, 2008 | T-Mobile Dash Smartphone
Tmobile dash instant messaging sound
my dash doesn't have instant messgaing.... what can i do to get the instant messgaing on my phone... plus the keyboard is not functioning well like it suppose to.. it works as key pad like d regular phone..but i can't use the whole keyboard...what can i do...???
Jul 07, 2008 | T-Mobile Dash Smartphone
My Tmo dash camera wont work
Sounds like the executable or file may be corrupted. I am sure you have already tried to restart the phone by pulling the battery.
Was there any error messages?
If all else fails I would Master reset the phone which makes it go back to factory settings.
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
May 04, 2008 | T-Mobile Dash Smartphone
Deleted camera from dash
I would back up any crucial information you have on your Dash and do a hard reset and when your Dash re-boots it should have all the original programs your phone came preinstalled with. it Dash Hard Reset
1. Select Start
2. Accessories
3. Clear Storage
4. Type 1234 in the box
5. Select YES. OR
- with the phone powered off
- press the two soft keys, yes the left and right soft keys which are the two dash keys labeled - -
- while keeping it pressed, press the power button down
- keep the power button pressed down for 1 - 2 seconds and then release the power button while still holding down the two soft keys. Keep holding down the soft keys until a black screen appears and prompts appear
- now release the soft keys and follow prompts
Apr 09, 2008 | T-Mobile Dash Smartphone
Trouble turning on my cell phone
I would take out the battery and keep the power button pressed for 15 seconds. After this power cycle, put the battery back in and try to turn it on.
Aug 29, 2007 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
100 people viewed this question
Top T-Mobile Computers & Internet Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
matt
matt
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
