I have a Buffalo g54 Wireless router, it keeps loosing wireless connection. Works fine when directly next to the router but when you move away it looses connection.
  • 4,806 Answers
Buffalo wireless routers are **** and never work right, i suggest you go out and buy either Netgear or Lynksis routers as these are the best, unfortunealeley there is no fix for this a the range of the routers are limited, stick to brand name equipment
kind regards and please don't forget to rate us
Posted on Dec 08, 2008
I have this router but i want to know hoe to secure my internet connection
By default, the firewall on it should block all incoming connections from the WAN or internet network port (good thing). Make sure you do two things : 1. Change the default password on the router, and 2. secure your wireless using WPA2 for authentication and AES or TKIP for encryption. Also, rename your SSID to something that doesn't give away that fact that your router is a buffalo. I'm paranoid, so I donot broadcast my SSID...if you are too, then this is a good option.
Oct 22, 2013 | Buffalo Technology AirStation G54...
I have the Buffalo WHR-G125 model, i have had it for around 2 years & for the past week i have to spend ages trying to connect my laptop to it, i have switched the plug off sometimes to reboot, i have...
I have seen a similar issue several time created by the cordless phone.
If you have your router too close to your cordless phone, you may have radio interference since both are working on a close bandwidth.
Please move one of the 2 away and tell me if you see any improvement.
regards
Mar 18, 2011 | Buffalo Technology AirStation G54...
I've had a new laptop but require my security key, model WBMR-G54 to access the security enabled network, from my old laptop.
If you've forgotten the wireless security key you entered when you set up the router you can reset it by connecting to the router directly with an ethernet cable instead of the wi-fi. Plug a cable into the router and then laptop and access the setup page for the router. See the manual (or download one from the buffalo site) for setup instructions.
Dec 27, 2010 | Buffalo Technology Buffalo AirStation...
I need to connect to one PC trougth my buffalo router, I have the Public IP, but I don{t konw hoe to configure the router and the pc
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Apr 28, 2010 | Buffalo Technology AirStation G54...
Wireless keep failing.
It might not be a router issue. If there is a DNS conflict, then check the connection settings on your computer. If possible, automatically assign IP and DNS.
Primary DNS should be the IP of your router or internet gateway (192.168.1.1 or similar). Secondary DNS 4.1.1.1
If your router is connected to the net and you can receive and send data, then the problem will be a local one (LAN rather than WAN).
If all else fails, reset the router and start from scratch.
Wheal :)
Feb 26, 2010 | Buffalo Technology AirStation G54...
Trying to connect buffalo router to comcast modem for wireless internet
You will need to use the MAC address of your PC. Do an IPConfig/all while connected with a ethernet cable. That's whatg you need to put in under Wan--> WAN MAC address
Jan 17, 2009 | Buffalo Technology AirStation G54...
Buffalo g54 keeps loosing wireless connection, it works perfectly fine when you are sitting right next to the router but when you move away, you loose connection instantly
The router has a reset button reset router as per instructions.Then on the laptop find and chose repair for the connection.RICHARDM69
Dec 08, 2008 | Computers & Internet
Problem with my buffalo airstation G54 WHR-HP-G54
  1. After unpacking your Buffalo wireless router, connect the ethernet cable from your jack to the rightmost ethernet port on the back of the router. This is the blue WAN port labeled "Internet". Next, use another ethernet cable to connect your computer to the router, using any of the 4 remaining open ethernet ports on the back. Finally, plug the AC adapter into the power port on the router and plug it into the wall.
  2. Once the router has been plugged into the network and powered on, the power light will come on and the other status lights on the front will go through a series of flashes. Once the leftmost diagnostic light labeled "Diag" has gone off and the light labeled "Router" has come on, this means your router has been initialized and is connected to the network.
  3. Now open a web browser window and enter 192.168.11.1 in the URL field and press enter. You will get a prompt to enter a username and password to access your router settings. You should enter "root" (without quotes) as the username and leave the password field blank, then click OK. You are now taken to a page where you can configure your Buffalo wireless router.
  4. Click on the Admin Config button on the top right of this page. Enter a name for your AirStation and click Apply. Wait for the router to restart with the new setting, you may have to refresh your browser window.
  5. Next click on the Password button in the small row of choices under Admin Config. The Administrator name is fixed as "root" however, you should now choose an Administrator Password (8 characters or less) and enter it in the two fields provided, then click Apply. Wait for the router to restart, and you will be prompted to login with the username "root" and the new password you just set up. If you choose a password over 8 characters long, you will be unable to login and will have to reset your wireless router by using the pinhole on the bottom.
  6. Next click on the Wireless Config button on the top, third from left. In the small row of choices under Wireless Config, click Basic(11g). Make sure the box labeled Enable next to the Wireless Radio setting is checked. For the SSID setting, switch to the second choice Use: and then choose a name for your wireless network. You should write this name down and keep it near your wireless router in case you forget it. Click Apply.
  7. Next click on the Security(11g) choice under Wireless Config along the top of the page. For the Wireless Authentication setting, select WPA/WPA2 mixedmode - PSK. For the WPA-PSK (Pre-Shared Key) field, choose a password that is between 8 and 63 characters (letters and numbers only) and enter it here. Click Apply. buffalo04.jpg
  8. Your Buffalo wireless router will restart and is now configured to connect securely to the Internet.
Jun 23, 2008 | Buffalo Technology AirStation G54...
Buffalo Airstation G54 wireless is not working
connect your computer straight to your internet modem.
If it works then connect the router after reset....
read the manual..if it does not work then return your router and get a new one or simply buy netgear..has been working for me Without problems for 4 years other than two years ago got fried due to electrical over charge
Apr 05, 2008 | Buffalo Technology AirStation WBR2-G54S...
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
