Light stays on after oil change
From FocusFanatics online - -
Resetting the oil life monitoring system
1. Turn the ignition key to the on position. Do not start the engine.
For vehicles with push-button start, press and hold the START/STOP
button for two seconds without pressing the brake pedal. Do not attempt
to start the engine.
2. Press both the accelerator and brake pedals at the same time.
3. Keep both pedals fully pressed.
4. After three seconds, the Service: Oil reset in prog. message will be
displayed.
5. After 25 seconds, the Service: Oil reset complete message will be
displayed.
6. Release both the accelerator and brake pedals.
7. The Service: Oil reset complete message will no longer be
displayed.
8. Rotate the key to the off position.
For vehicles with push-button start, press the START/STOP button to
turn the vehicle off completely.
SOURCE: 2006 Ford Explorer "Oil Change Required" light is still on after changing the oil
IF YOU FIND THIS INFO USEFUL PLEASE RATE ME AS A FIXYA! THANKS
Oil Change Reset
A press of the OIL CHANGE RESET switch will allow you to
reset the oil life feature to 100% (or your Personalized Oil Reset
Percentage). After you have the oil changed, you must execute
the following procedure. Press the OIL CHANGE RESET switch
and hold for five seconds as the M/C counts down for five
seconds. After a successful reset the Message Center will display
“OIL LIFE RESET TO 100%.” If you have established a
Personalized Oil Reset Percentage, the display will show that
percentage instead of 100%. To ensure accurate oil life
indicators, perform this reset procedure only after an oil change.
Your Personalized Oil Reset Percentage allows you to establish a
smaller oil change interval than the manufacturer’s
recommended interval. To establish your Personalized Oil Reset
Percentage perform the following procedure:
1. Press and hold the OIL CHANGE RESET switch and press
the RESET switch while the display is still counting down
the 5 seconds to reset. The display will change to “START
OIL LIFE AT XXX%.”
2. Press the OIL CHANGE RESET switch until the displayed
percentage is the Personalized Oil Reset Percentage that you
desire. Your choices are 100%, 90%, 80%, 70%, 60%, 50%,
40% and 30%.
SOURCE: the service engine soon light stays on i just change oil
you can try taking the positive cable off for about 3-secs and check in you owner manual to see if it tell you how and if you do have one try this website www.edmunds.com to see if you can download one for you car.
SOURCE: FORD FOCUS OIL LIGHT STAYING ON
i have exactly the same problem, same model and year, car runs perfect but oil light comes on after 5 mins or so. its got me stumped!
SOURCE: my abs light stays on on my ford focus
when the ABS light stays on it means there is a fault present in the ABS system and the ABS has been disabled, as long as the light is on u just have regular brakes with no ABS, there are many thinbgs that can turn the light on, most common is one of the wheel speed sensors is defective, since these sensors are about $75-100 each and there are 4 of them guessing is a poor idea, so what u need to do is have the ABS systwem tested, there will be a fault code present to help narrow down the defective part or wiring.
Battery and Oil Warning Light
Comes ON?
http://technoanswers.blogspot.in/2012/06/2003-chrysler-pt-cruiser-battery-and.html
The
oil is getting leaked from its running area. The oil pump has to be pressure
tested by pressure test to confirm the leak and area of leak: -----
For
step by step troubleshooting check the help links mentioned below: -----
Click
the link below: -----
http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
http://whatisbyme.blogspot.in/2012/06/high-oil-level-on-dipstick.html
Kia Sportage
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
http://whatisbyme.blogspot.in/2012/06/overfilling-oil-in-engine.html
http://schematicsdiagram.blogspot.in/2012/06/2000-dodge-ram-3500-cummins-diesel-oil.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
http://whoisbyme.blogspot.in/2012/07/how-to-reset-oil-change-indicator.html
These
details will help.
Thanks.
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
The information below was complied by me, it explains what causes the check engine light to come on and the process of finding the cause.
When the Check Engine light (or Service Engine Soon or small picture of an engine) is turned on, the systems computer control unit (called the PCM) has sensed a fault in the electronic controls of the engine and/or the emission system. When this happens you will seldom feel the car engine run any different. There are about 200 possible system faults (the gas cap is just one of them) that turn the Check Engine light on, to know what has developed a problem you must have the system tested, this is called an OBD2 fault code test, Kragen/Oriley and Autozone parts stores (USA only) do this testing for free.
Other auto parts stores in non USA locations may offer this service call your local auto parts stores to confirm.
