Code Search
If after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds
OK.
0704 0002 0406 0007 0011
................. 0611 0811 0312 0514 0720
................. 0102 0502 0601 0817 0917
................. 0835 0901 0103 0803 0211
................. 0912 0114 0519 0320 0420
Direct Code Entry
button.
flashes.
be controlled.
button.
Code Search Method.
the code.
OK.
0906 0702 0203 0306
................. 0208 0911 0842 0942 0504
Direct Code Entry
button.
flashes.
be controlled.
button.
Code Search Method.
the code.
OK.
0906 0702 0203 0306
Direct Code Entry
button.
flashes.
be controlled.
button.
Code Search Method.
the code.
OK
