Question about HP DeskJet 5550 InkJet Printer
Just won't print
I changed the black ink cartridge (56) and have not been able to print since then. Have checked cords to printer, have replugged the power plug, have turned printer off/on, have removed all queued documents and started over - nothing.  Green power light is on.
  • 2 more comments
  • esbudden Dec 13, 2008
    It did not attempt to print. However a friend managed somehow to get it to print a few documents but soon grinding noises came from inside the printer along with a faint, odd smell.  I finally turned it off, disconnected it entirely, and, in desperation, bought a new hp officejet J6480 so I could get on with my now heavily backlogged print queue.  Thanks for trying to help but it's too late.
  • Anonymous Dec 20, 2008
    Exactly the same thing has happened to my printer. It just won't print black at all even though I have done all the calibration tests etc. Colour prints fine but black just prints blank.
    Do you think there is any way to resolve this at all?
  • ruendyll Jan 08, 2009
    My printer needed a refill. So i just went to refill it, but now it keeps indicating that it needs ink and wont let me print anything.
  • JDTec
    JDTec May 11, 2010
    Do you mean that it does not attempt to print or prints blank pages?
  • HP Master
  • 4,338 Answers
Sorry to hear that. Sounds like there was an electrical failure. It probably was rendered uneconomical to repair if it was on the logic board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 13, 2008
We have just put a new black ink cartridge in our printer and now it won't print. The computer says it is error# 5200 and to see the user guide. The manuals don;t have any info to help. I have tried...
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
Jul 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Just changed ink cartridges and unable to use printer. Keeps stating printhead missing or has come loose but it isn't. Before this happened, wouldn't print the black ink after I'd installed...
Your printhead is bad and you should have it replaced.This should cost you about $56 if you are in the US
Also you should reolace all the waste ink absorbers,reset the counter to zero and re-insert the ink cartridges.
To replace the ink cartridges
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Jun 12, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
Installed new ink cartridge and it won't work
did you check if the printer printed a cartridge alignment sheet.
you can try power flee initially
take out the cartridge
unplug the power cord
press the power button for 30 seconds
and then replug the cable
when it asks for putting the cartridge
put the cartrige in its respective slot
also make sure that you keep t least one paper on the tray so thst the printer prints an alignment sheet
,it shjould work fine
Hope this helps
Take Care
Jun 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
HP7660 Photosmart Printer
It comes with HP #57 (C6657 A)—Tri-color print cartridge and HP #56 (C6656A)—Black print cartridge and the 56 must always be in there (the black one) but acceptable replacements for the color one are as follows: HP #58 (C6658A)—Photo print cartridge I suggest for the best photos use 58 and 56.
Feb 28, 2009 | HP PhotoSmart 7660 InkJet Printer
Black ink not working on HP C5180 Photosmart
Try a hard restart, which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. If that does not work, then rerun the CD used to install the printer. Both techniques reprogram the electronics, to a certain extent.
You can also visit the HP website, to see what solutions are being offered for various printer problems. They probably have a number to call, in case you need to talk to a technician.
Hope these suggestions help you out.
Jun 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
We just attached the macbook to the hppsc 1350v all in one printer and new print cartridges. When attempting to print, message reads"color print cartridge not compatible with this printer". We know we have...
Just to confirm pls:
1. the new print cartridges are original HP inks;
2. you have remove the bright pink tape from the ink cartridges;
3. the black is on the right side and the color is on the left side.
You can try removing both cartridges and clean the gold colored contacts where the pink tape was. Pls do the same to the mate pins in the cartridge holder in the printer.
Try again. If this does not be corrective, you may need to change inks again.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 02, 2008 | Computers & Internet
HP DeskJet 5550 InkJet Printer Logo
61 people viewed this question
Ben Johnson
