Question about Toshiba Satellite P35-S609 Notebook
The Toshiba Satellite P35-S609 support an DD of the 160 Gigas
Please help me with this question
  • Anonymous Mar 15, 2014
    i am unable to boot, recovery disc will not recover my computer,
1/2 of my screen have vertical lines
Most likely bad lcd panel. Try connect to external monitor to confirm.
Paul
Dec 25, 2013 | Toshiba Satellite P35-S609 Notebook
Screen flickers
Does it flicker on an external screen? If it does you have a GPU issue, if not the screen/invertor is probably faulty.
Vertical lines on my screen
If after rebooting, they are still there, try an external screen. If the fault shows up on both, you have a GPU issue, if not you have a screen issue.
Toshiba satellite p35-s609 screen darken.
It is almost certainly the LCD inverter which is the cause of your issue. It ism ore common for the inverter to develop a fault than a backlight bulb on the LCD (I used to work in a Toshiba repair centre).
Replacing the inverter should be simple, just make sure the unit is powered off with the battery removed so you don't get an electric shock.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite P35-S609 Notebook
Toshiba Satellite P35-S609 xp System - hello is there a service manual for this product?
Go to Toshibas website and you can get it off of their website.... Or google "Get Manual for Toshiba P35-S609 Laptop"
Good luck Hope that helps
May 21, 2010 | Toshiba Satellite P35-S609 Notebook
Won't stay running
Update the Bios Driver for the computer off of toshibas website and it should fix it, I had the same exact problem!!! And if that doesnt solve the problem you have a bad battery...
Feel free to Email me with questions at newlook_inc@hotmail.com
hope this helps!! Good Luck
Jeremy
Sep 24, 2009 | Toshiba Satellite P35-S609 Notebook
I have a Toshiba Satellite P35-S609. I upgraded Windows XP Pro to Vista Ultimate. Three devices stopped working in full capacity: 1. The ATI Mobilityy Radeon 9100 IGP video driver was not found -...
Not all PC are capable of running Vista at its full potential. This is not a Microsoft fault, but equipment manufaturers not supplying the drivers for older hardware. I recommend you to run the Vista Upgrade Advisor from the Microsoft website, to see if your laptop can run (that flavor of) Vista.
Apr 17, 2009 | Toshiba Satellite P35-S609 Notebook
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Toshiba Satellite P35-S609 Notebook Logo
183 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
