My computer does not recognise my hardisk in the bios
My pc was working fine but earlear because my hardrive is only a 20 GB,decided to shut down the pc and not unplug it,and just clicked the rear switch to zero,then i uninstalled my hardrive to try the other 80GB,drive to see if it would work but would not boot up even with 3 versions of booters,so i put my own one back in to my pc and that wont reeboot eitther now the pc does not go as far as any modes to start and in the bios it does not recognise my hardrive anywhere?please would welcome some advice on how to resolve this issue,any help desperate to get soughted,ive borrowed a pc to ask this question for any aid,regards,garnedd
  • Alan Jones
    Alan Jones Dec 10, 2008
    after a close inspection of the cable ribbon and found it to have **** in 1 area,put spare one in and it rebooted with all software and harware problems working,thank you for your timr and knowledge to help me,many regards,garnedd
  • 2,692 Answers
Reset you BIOS to the default values and see if that will work. Also check that your IDE? drive is set to MASTER and that the cable ribbon is in correctly on both the MB and the HD.
Posted on Dec 09, 2008
I have a D865perl MB some times for no reason my computer shuts down. It is a pain to restart, i have to turn it on and off atleast 20 times
That looks a hardisk failure.
Set the BiOS to "max. default operation", save upon exit. If you still got the same problem replace the HARDiSK.
Try to replace the hardisk and install your favorite OS.
Hope that helps!
Dec 02, 2011 | Intel D865PERL Motherboard
My passport 500gb external just stopped working. It froze up so I removed it and plugged it back in. When I plugged it back into my computer it starts spinning but then makes a click sound and stops.
The clicking sound is caused by the spindle inside the hardrive, because it was not removed properly. Just connect you external hardrive to your computer, if it makes the clicking sound again dont remove it yet, just restart your computer properly. In that way all the devices connected to the computer will be refreshed and properly shut down. If it is not detected still, unplug the haardrive then try another USB port. Recommended ports are at the back of the CPU if your using a desktop. These USB ports have higher voltage output that can power up all external hardrives properly.
Jan 13, 2011 | Western Digital My Passport Essential...
My Dell Desktop cannot start in Safe Mode
hi there,
you mention you have change your hardisk,you have to check if your hardisk was configure in cmos and bios set up, first whaen you start your computer press F2 then bios set up appear,check your device if
was connected on your system.on main menu check your ram if it was connectd,then press arrow right to advanced menu check your hardisk from IDE configuration if both hardisk and memory was installed or cofigured by your system.go to boot menu to set your device, on boot menu,scroll it from boot device priority
if you assure there is windows installed already on your hardisk,priority your hardisk,second your cd room,third floopy F10 to save and restart your computer,If no sytem was appears you must reinstalled your windows but you should change again
the boot set by priority the cd room instead of hardisk in order to put windows on your F10 again to save and restart your computer
to install your windows
insert windows cd on cd room
wait to configure your computer by the cd windows
then ff the windows installation procedure
until windows installation was finish.have a nice day don't forget to rate me please.thank you
Feb 21, 2010 | Dell Dimension 3100 PC Desktop
Compaq Presario S3040SE PC Desktop was working fine. when i turned it on next day screen says operating system not found. restart. now monitor wont kick on and hard drive light doesnt come on. only power...
Normaly when you get the error that the operating system cant be found, it is a indication that the hardrive has either gone bad, or somehow some of the system files got deleted. I would say though since the hard drive light wont come on it could be the hardrive has shut down completely. But you still should see the company image of your computer when you start it up, (the bios screen)
A bad hardrive would be my first guess, 2nd problem if its not your harddrive would be a new power supply.
Dec 31, 2009 | HP Compaq Presario S3040SE (DF222AR#ABA)...
How do to install slave drive Seagate Barracuda 7200.9. Does it has to be to the motherboard or to a card in my computer? How do I set the pins in what order?
if y0our going to slave one hardrive you need to set that hardrive jumper into slave format....check your hardisk if where pin should it e placed...usually there is a direction where to set the jumper for slaving the hardrive.
Oct 28, 2009 | Seagate Barracuda 7200.9 ST3400633A 400 GB...
try manually configure the HDD to the BIOS setting.
input the drive parameters ( printed on the top of HDD)
next use the manufacturer disk tools of your hard drive ( download it to manufacturer web site)
Mar 23, 2009 | Western Digital 500GB My Book World...
Pc hardrive seems to be working more than usual
see if in your power options what you put for the amount of energy devoted to your hardisk
also see in your system about your harddisk setting
to assume the worst you have abnormal operation/a virus
and it would cause your system to use it harddisk more
but i don't think you should worry
harddisks are designed to work hard
hope to help
Dec 14, 2008 | Computers & Internet
Hi There,
1) Unplug the ide cable from the motherboard, and try booting, It should through an error.. which is good.
2) If it troughs an error than re-plug the ide cable back in and make sure hard drive is plugged in tight.
3) boot up he system and go to the bois
4) In the bois select auto detect drive (if you have that option) if selected than save the bois
5) if the driv has been found then you system should boot up correctly assuming that you have an operationg system installed.
Please let me know how you get on.
Dec 08, 2008 | ASUS P5VD2-MX SE Motherboard
My hardrive is not picked up in the BIOS
check whether the hard disk is detecting on BIOS or not
Oct 29, 2008 | Lenovo ThinkPad T61 Notebook
Dell dimension 4600
check in the bios that it is your new hardrive it is seeing, and not your old one still sitting in thr bios memory, as taking out the battery doesnt always delete the cmos memory.
There shoul be an option in the bios to auto recognise the drive
Aug 24, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
David Payne
David Payne
