Lost remote tv locked and cant change settings in menu to unlock
I lost my remote for my magnavox tv set model no. MPTV68A.
the tv has locked me out in a foriegn language and i cant do anything apart from turn it on
cant do anything else with it
just wondering if there is a way to unlock the tv without a remote or universal remote
  • kenhusker Dec 09, 2008
    I have the same problem. I can turn the tv on and I get a blue screen with video 2 on it. I go to menuand I can only enter volume. Any suggestion. The actual remote is missing and we are using a universal remote
  • 556 Answers
SOURCE: magnavox universal remote for sanyo tv
ok...got this nice sanyo ds19310 from brother without remote..have a magnavox universal remote but don't have code for tv or if i can use magnavox codes or can i set remote to it another way...thanks for any help i can get! megnavox tv code is Press following key combination 0>6>2>5>9>6>MENU to select item press cursor(up)and (down) to change item value press cursor(right)and (left) cancellation of service mode press POWER button on the set regards thanks
Posted on Sep 11, 2007
  • 67 Answers
SOURCE: Magnavox MPTV68A "Magnavox" emblem is displayed and won't disappear
I don't know the exact TV, but Magnavox usually have an item or two items in the menu system where the "Magnavox" and also the "blue screen of death" can be disabled. Look in your manual.
I'd suggest the reason it appears is temporary loss of signal from the antenna, set top box, cable system or whatever it is you receive your TV programming via. I don't have an answer as to why it occurs watching video, but turning off the logo and blue screen should help. If it still occurs, it's time for professional intervention!
Posted on Feb 11, 2008
jerryg50
  • 1673 Answers
SOURCE: Get addvice
This is a good one!
Did you ask the dealer where you bought the set?
Did you enquire about the local Daewoo service rep for your area?
If the above is not useful, I would do a Google search for other news groups and sites that deal with Daewoo.
Daewoo Contacts below:
Daewoo Daytech consumer and industrial for North America:
http://www.daytek.ca/contact.html
Daewoo Corperate World Wide Info:
http://www.daewoo.com/english/index.jsp
Jerry G.
Posted on Apr 13, 2008
SOURCE: Magnavox mptv68a
i have a remote for a different phillips tv and it does not work on my locked phillips tv.
Posted on Apr 23, 2008
Ironfist109
  • 3018 Answers
SOURCE: I have a TruFlat RCA
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Posted on Apr 30, 2011
LOST REMOTE AND TV IS LOCKED
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jan 08, 2013 | RCA Televison & Video
Lost remote tv fpa lock is on tv has solid red light help
This is the method to unlock an RCA tV:
Nov 23, 2012 | RCA Televison & Video
We cant play dvds in it because it has a lock on it and we cant get the code to be able to unlock it can you help us
Try the following methods. One of them should resolve your issue.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Regards,
G33k
May 09, 2011 | RCA Televison & Video
Lost parental control password
Hello
You can unlock your RCA tv by the folloing method. After unlocking it, you have to set a new parentioal control password.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Feb 26, 2011 | RCA 27F534T TV
Its a rca tv model # 20v500t serial # f075e5e61 i accidently set the fra lock or something like that in the menu screen and cant turn the tv back on and dont have the remote
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  4. Hold down EJECT button on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jan 09, 2011 | RCA Televison & Video
Tv is not working it is stuck on channel 3 and stays there and need it to go on output in front and can't watch any channels with direct tv satalite very difficult lost remote and need code this tv and...
Hello
If you have its original remote control you can unlock its parential settings and reset it. Then only you can watch other channels also. I'm ver sorry to say that if you lost your TVs remote control, you will be unable to unlock it. Try to get a remote from any of your friends who owns the same model number RCA TV. If you are able to get it, do the following with that remote, and reset the V-chip. Try to purchase one new remote control from RCA.
OK
Happy New Year
Dec 31, 2010 | RCA TruFlat 27F520T 27" TV
Locked tv
You need to buy a remote for that TV. They're available online for around $39. This site has them in stock, but you can shop around to be sure its a good price. When you receive it, turn on your TV and press menu on the remote and turn off child lock. Click the Remote here:
http://www.newremotecontrol.com/catalog/dyn_models_accys.php?modnum=27MS343S&hash=e91e6348157868de9dd8b25c81aebfb9
Nov 19, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox mptv68a
any magnavox controler will work just put in some good batteries . lots retail wholesale stores like walmart carries magnavox tv remotes but make sure its a magnavox.
Apr 10, 2008 | Philips Magnavox 27MS343S 27" TV
Magnovax tl712 c107 model #
Get a universal remote or go online and order a replacement original remote for your model. Then use the remote to enter the menu, unlock any child locks, make sure the set is in standard cable mode and do an autoprogram.
Aug 21, 2007 | Philips Magnavox 27MS343S 27" TV
Magnavox 68 cm tv model mptv68a
i have a magnavax mptv68a, the red button is on but the screen is blank, it doesn't even appear to turn on. can you advise me on what to do
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
