Question about Kitchen Ranges
Oven under cooks - Kitchen Ranges
    Habit-Forming:
  • 171 Answers
You can calibrate the oven temperature, the adjustment screw is inside the thermostat shaft. when you remove the oven knob.
Posted on Dec 09, 2008
How do you cook a hickory smoked ham shank portion that is fully cooked already?
I place ham in a large roasting pan or large rectangular pan using a rack under the ham. Set oven to 325 and cook 15-18 minutes per pound. I make a glaze. I glaze half way through cooking time and then a second time 15 minutes prior to removing from oven.
Apr 16, 2017 | Grilling
Do I need to put water under the roaster pan?
Under the pan or inside the pan?
If it is a covered roaster no you don't need to. I put about half a cup of water in the pan to keep some moisture inside there at the start of cooking.
Nov 25, 2015 | Sunbeam Cksbrs16-b Quart Roaster Oven...
Why is the oven stop cooking before cooking time is expired, convention and microwave
In which case I'd take it back under warranty and ask for the warranty to be extended.
Alternatively (in the UK) you can return it for a refund because it is not of merchantable quality.
Mar 10, 2015 | Microwave Ovens
I have had 2 microwave ovens they both leaked water from the door while cooking,when nothing boils over,no mater what i cook
That is not normal, a test should be done to check microwave leakage to make sure numbers are within safety limits.
Apr 21, 2012 | Emerson MW8889SB Microwave Ovens
Is this model of west bend crock pots oven safe? if so, to what oven degrees and with the lid on or off?
The Instruction Manual for your product is available here:
http://www.westbend.com/supportdata/L5531B_5-6Qt%20CrkryCookers_ALL.pdf
Under the section on Heat Precautions you will note:
Do not use the cooking pot or cover on the stovetop, under the broiler, in the freezer, or in the oven. You may use the cooking pot in the microwave oven, but do not place the glass cover in the microwave oven as it has a metal ring.
Sorry someone has not responded sooner.
Jan 01, 2011 | West Bend 85156
Small amount of white smoke coming out of kenmore convection microwave in oven mode
That is usually caused by a build up of fat from microwave cooking on the heating element. It will clear under normal conditions and return if one cooks foods like bacon etc, un covered to prevent splashing of the food that is being cooked.
Hope that helps.
Oct 31, 2010 | Kenmore 63793 Convection / Microwave Oven
We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
Frozen food should be defrosted before cooking in halogen ovens.
Halogen ovens use only radiant heat and will not cook the centre of frozen food.
Jan 21, 2010 | Ovens
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Oven will over cook sometimes and other times it will under cook
the only thing that will do that is a wonky oven thermostat. replace it
Oct 18, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore elect oven 40499
NOT SURE ABOUT THIS MODEL BUT SOME OVENS HAVE A CALIBRATION PROCEDURE THAT MUST BE DONE AFTER CHANGING THERMOSTAT CHECK WITH APPLIANCE SHOP OR DEALER FOR ANSWER DONT HAVE BOOKS ON THIS MODEL
Dec 20, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
275 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
