Question about Dryers
Indesit dryer only blowing cold air - Dryers
  • 4 more comments
  • wjulie19 Dec 08, 2008
    Hi
    The dryer is a condenser
    Thanks
    Julie
  • wjulie19 Dec 10, 2008
    No, still have problem with dryer.
    Hi Barry
    Many thanks in replying, sorry not got back sooner, my hubby is disabled and had to take him to the hospital.
    The dryer has a solid door on the front, (can't see drum), on the front of the dryer it has 3 dials - start, full/1/2 full and timer.
    When you open the door there is a fluff gatherer (sorry don't know proper name) on the inside of the door itself, there is a thing that you pull out at the bottom of the dryer (presume condenser at the front under drum and then a box thing that collects water.
    There is a sticker on the inside s/n 409080867 and on the back of the dryer there is a sticker which states model number 29327
    Many thanks for taking time out with this problem.
    Kind regards
    Julie
    Hi Barry
    You are not a pest, have taken another look and yes there is another number G75C
    Many thanks
    Julie
  • wjulie19 Dec 11, 2008
    When looking for model number noticed light on machine, I always thought this was to tell you machine is on, there is a little picture next to it, does this help?
    Thanks
    Julie
    Hi Barry
    Many thanks for your advise, my brother in law is coming round tonight and has a multimeter to check the above, will let you know what happens.
    Thank you for your help
    Julie
  • 3,463 Answers
You need to check heater and thermostat(s), with a multimeter.
If o/k then could be faulty timer.
You did not state wether it was a vented dryer, or a condenser dryer., as this makes a difference to the solution, because other components are involved.
Posted on Dec 08, 2008
  • 2 more comments
  • Barry Coates
    Barry Coates Dec 10, 2008
    Have you soled your problem with the dryer.
  • Barry Coates
    Hi Lulie. can I ask you for the exact model of the dryer, because depending on which one it is there are several different solutions possible?
    Does it have a display at all on the control panel?
    Any more info would help.
    'Cheers.
    Barry
  • Barry Coates
    Hi Julie.
    Sorry to be a pest, but the number you gave me is not the model number.
    What you are looking for is:Mod no-or Cat no.
    It is sometimes on the front of the dryer at the top., or inside the door. Look for a number starting (G) OR (IS).
    Barry.
  • Barry Coates
    Barry Coates Dec 11, 2008
    Hi Julie. Thanks for further info.
    Maybe now we can sort your problem out.
    i expect you have cleaned the lint filter at the front and emptyed the water container and pushed it back in properly.
    Check the air vents are clean at the front and rear of the dryer.
    Make sure you have selected the right heat setting and not overload or put in very wet clothes.
    If after having checked all these thigs and it it still does not heat, then it narrows it down to about 4 possibilities.
    1-heater and or thermostat(s) faulty.
    2-faulty timer.
    3-faulty heater relay
    4-bad or broken connection.
    There is nothing else I can suggest, other than calling some one in to look at it.
    If you call indesit in, it is going to cost you at least £90.00 to get an engineer to come out and fix it.
    suggest you try and find some one locally that you knpw and can trust to fix it.
    Good luck.
    Barry.
Is70c indesit condenser blowing cold air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[]][
Aug 10, 2011 | Dryers
Is70cuk dryer only blowing cold air, all filters are cleaned water emptied
the one shot stat has blown on the heater. remove rear heater cover and two smaller screws holding element to the cover. you will see the two round stats. both must be replaced. part numer is 1703200, aprox £25.
Jul 06, 2011 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Indesit Dryers
I have a indesit is31vu tumble dryer and it started to blow cold air i think it must be the thermostat hust wondered is it easy to change or am i better off buying new one?
There is more than 1 thermostat, and it could be the element.
TThe parts are located at the rear of the dryer behind a removeable panel.
You need a meter to test them with.
Hope this helps.
Jan 18, 2010 | Dryers
Why is my indesit dryer blowing out cold air
It is more than likely that the heater element, and or the thermostat/s are faulty.
The only sure way to determine the cause of the prob, is to test them with an electric test meter.
Please rate my soution.
Thanks.
Nov 18, 2009 | Dryers
Indesit 1560v wont dry cloths it is just blowing cold air . rear vent is clear
you must replace the thermostats on the element.
Oct 24, 2009 | Dryers
Tumble dryer running but only blowing cold air
If your dryer is turning then things are not so bad. If a dryer is not heating then you need to check a few things.
First disconnect the power to the unit. Then you must check the heating element and the limits which are mounted on the heating box.
Remove one lead from the element and check for continuity thru the element. If you have continuity then check the limit by measuring for continuity, again you must remove one of the leads. This should solve your problem
Sep 15, 2009 | Dryers
An indesit tumble dryer, only blowing cold air.
Most likely heating element or thermal cut-off is bad, or both.
Sep 14, 2017 | Dryers
My Indesit IS70C is only blowing cold air. It was fine this morning. Do we have to remove the silver back to get to the thermostat?
Remove the lower rear panel, there you will see the heater element and thermostats, make sure the heater is o/k, and replace both stats.
Plz rate my solution
Thanks.
Dec 18, 2008 | Dryers
Dryers Logo
168 people viewed this question
Top Dryers Experts
