Question about Centrios EDW8020 DVD Recorder
Will not power on
Hi. I unplugged for a few weeks while I took the TV outta the room. When I try to power up the unit this morn, the red standby light comes on, the time flashes --:-- and a little , really small circle symbol that might be a watch or clock. I cannot get the thing to turn on. Any advice. tia, kmh
Thanks. i guess that means the trash heap and another toy coming my way... appreciate the response., k
Posted on Mar 19, 2007
    Genius:
  • 1,074 Answers
You have damged the micro chip when you unpluged your set it is possible that a static charge caused it have cheked out by tech.as you cannot do it by yourself if you are not a qualified tech.
Picture on the TV went off and the on off red/green led light is flashing orange. I have turned the TV on and off the picture comes on for a few seconds then goes off again and the green light goes to...
usually the orange light is an indication that there is a problem with the power supply maybe there was a power surge. It shuts it self off to protect the tv from any further damage. If your tv is outta warrenty then u shld try googlin your model number and your problem. I had a issue with my tv and i searched my specific tv and discovered many ppl had the same problem and thanks to them it only cost 38 dollars to fix my tv You could have the same problem mine did it was a blown capacitor they are like $3.00 i had to take the back off mine to see if that was the problem and its easy to see they r like little batteries and most are flat but we had to that were puffed out at the end we took that board out of the tv and took it to a tv repair place it took3 hrs and its good as new. Had we not found the solution online we probably would have had to spend $100's to have it fixed.. Good luck I know it can be very frustrating, If u have a warrenty dont take the tv apart cause then they will void your warrenty.
Feb 16, 2011 | Televison & Video
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
4 blinking red lights in power/standby
I would recommend replacing the fan, cleaning it doesn't solve the problem...If it does, it's only a temporary fix. Replacement fan is around $30 and easy enough to do yourself...
Sep 15, 2008 | Sony KDS-R50XBR1 50" HDTV
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
JVC LT-26DF7BK won't turn on
Hi I had the same problem with my LT-26C31BJE. The TV just stuck in standby mode. If you tried to turn it on, it seemed like it tried to power up, but then reverted back to standby.
I solved it this way. I took the back off the TV (unplugged of course) and made sure all visible contacts were home (they all seemed to be). Also to the right of where the power lead enters the box there is a small fuse, 250V 6.3 W. I replaced this fuse and the TV now works fine.
Dec 27, 2007 | Televison & Video
Does not turn on.
i had my power supply blow on mine within the first year took it in because i had extended warranty and they fixed it, only problem was finding a dealer in my area to fix it, then took over a week, because of customer support issues
Oct 09, 2007 | Sylvania 6626LCT 26 in. LCD Television
Centrios EDW8020 DVD Recorder Logo
69 people viewed this question
Top Centrios Televison & Video Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Tom Chichester
Are you a Centrios Televison and Video Expert? Answer questions, earn points and help others
