Question about Dayton 511 Utility Heater
I need a gas valve for a Dayton model 3E473A wall furnace
I have an older Dayton natural gas wall furnace, model 3E473A that has a bad gas valve. I think the part number is 7000ARB for the gas valve. I could also use a new thermocouple but the one I have is still working so this is not a priority. The parts for this firnace are no longer available from Grainger.
  • Dayton Master
  • 2,873 Answers
You can look for a gas that we go in place of the one you have, try national energy they sell gas valves and should have one to fit your heater , i would change the thermocouple as well .
hope this helps
Posted on Dec 08, 2008
  • Paul Carew Jan 05, 2009
    try desaint .com for spares
2YV14 need to find a new replacement fan blade and hub for a dayton wall heater model #2YV14
Hello Jeffrey Messenger,
Dayton is a big name product available at GRAINGER.
Electric Wall Furnace,
Recessed or Surface, 240VAC, Watts 9200
Replacement Parts
H
elp finding replacement parts?
Please call 1-800-GRAINGER
(1-800-472-4643)
The 2yv14 is a well known heater... sadly it has been
MANY years since I have purchased any
Dayton equipment... but GRAINGER RETAIL
OUTLETS WERE The reliable PLACE TO GO.
(see below).
GRAINGER
https://www.grainger.com/category/dayton/ecatalog/N-1z13ntg
DAYTON-Electric-Wall-Furnace-2YV14
Electric Wall Furnace Recessed or Surface 240VAC Watts 9200
Carnac the Magnificent
Mar 22, 2017 | Dayton Heating & Cooling
Model #3e243b Dayton heater chg from LP to NG
Dayton is primarily sold by www.Grainger.com . You must purchase a re-jetting kit (Natural Gas Valve) from them to accomplish this.
Grainger Part # natural-gas-valve-1fek5_as01.jpg view_larger_button.gif Natural Gas Valve
Item # 1FEK5
Natural Gas Valve, For Use With 5VD61, 5VD63, 5VD65 DAYTON
1FEK5 4401 Usually ships
1-3 Days 1 $144.30 item_sale_symbol.gifSale Price$115.44 See All: Parts
Sep 23, 2011 | Dayton (3E379) Heater
Pilot runs gas valve clicks but no ignition dayton 3e226c
There is a small Allen head screw in the gas valve that can be removed to test for gas after the gas valve. When the gas valve opens, gas should be present at that port. If none, you have a bad gas valve. If you gas gas, then there must be a restriction at the main burner.
Jan 21, 2011 | Dayton Gas Furnace Heater
Looking to change heater3e239 to gas from lp what parts do i need
Contact graingers at grainger.com. Give them the model number and tell them you need a conversion kit from LP to Natural Gas.
Jan 19, 2010 | Dayton Gas Furnace Heater
Need ignitor and gas valve for heater
They sell dayton stuff at Graingers
Dec 04, 2009 | Dayton G73 Utility Heater
No ignition on dayton gas furnace. how hard is it to install new gas valve on a dayton furnace
not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
Oct 31, 2009 | Dayton Gas Furnace Heater
I want to convert a model 3e476b propane counter
The Dayton brand belongs to WWGrainger if the parts are available that would be the only place.
Oct 02, 2009 | Dayton Gas Furnace Heater
Switch a natural gas furnace over to lp
WW Granger is the biggest supplier I know of for dayton. Consult them for information and if its still available.
In lue of this find the oldest repair man you trust and ask him if he knowes anything about them. I know I could help if I could see what you have and had some more questions answered. Pilot ignition? Gas valve model? Does it have a regulator in the gas valve? Then you have to find a kit to block open the regulator. Then change the orfices to correct size or solder and redrill the old ones. Then maybe adjust the combustion air, and you may have to change the pilot burner orfice and adjust it.
After that you can fill the LP tank.
Hope this helps IF so please grade me accordingly and Good Luck.
Mar 03, 2009 | Heating & Cooling
Dayton 3e735 standing wall furnace
Wall furnace? maybe and maybe not! if there is a way it would be on the gas valve and be labeled (though it might be hard to read). often the adjustment screw is under another screw but always labeled.
Feb 03, 2009 | Dayton Gas Furnace Heater
Fault Code on Dayton Gas Furnace
This happens when the furnaces tries to light to many times and doesnt succeed. If you stand in front of the furnace while it is coming on, you will be able to hear the problem. If its an electronic start, there will be a clicking sound, followed by the gas valve opening to start it. If it has a pilot light, make sure it is lit, then listen for the gas to come out, it will make a hissing sound. If no gas is coming out, first double check to see if the gas is turned on to the unit, if it is, then its possibly the gas valve. Oh, if it is electronic, and you hear gas, but dont see a glow inside the furnace, or no glow or gas, it could be the ignite. Hope this helps.
Jan 07, 2009 | Dayton Gas Furnace Heater
Dayton 511 Utility Heater Logo
440 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
