Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Need a manual to learn how to use my range. Mod. # RF367LXSB Mario
    President:
  • Whirlpool Master
  • 2,651 Answers
Frigidaire electric oven mod cfeb786jgs3 cannot see th tempurature indicator
Good Morning Friend,
I understand that you are unable to see the temperature display on your Frigidaire range, model# CFEB786JGS3. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before setting the temperature for your oven. If you are still having trouble with the display, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire Ovens
I would like to obtain an operators manual for a whirlpool electric range.
Whirlpool has the manuals for many of their appliances on their web site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . You need to provide the model number of the range to get the correct manual. From the Whirlpool site, click Search after entering the model number. For most ranges, the model number will be on a plaque behind the storage drawer on the rim of the unit.
If you add a comment with the model number, I will be glad to see if the manual is available.
I hope this helps.
Dec 10, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I need a manual for Whirlpool Range Mod. # GLP85200. Something that shows how to get to the Hidden bake element.
Welcome to FixYa.
The Whirpool Range Manual is Generic, you can download it >>HERE (in PDF format).
To remove the bake element, remove the screw that holds it from the inside then pull it outwards.
You need to put a little force.
Thank you for using FixYa.
Jas
Sep 01, 2011 | Ovens
Kenmore Electric Double Oven Mod 9114832592992 got F2 code in middle of selfclean what do I need to fix?
Hi, i found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
OR....
F2 Oven temperature sensor shorted Replace oven temperature sensor
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Oct 26, 2010 | Kenmore Ovens
We need to replace the ignitor on a fgf326asf, we
The stove Frigidaire Mod. FGF326ASF give an F3 error don't have manual instructions, could you tell me please what that means
May 07, 2010 | Frigidaire FGB24S5A Gas Single Oven
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Manual for Smeg SpA42016
SpA 42016 is Smeg's postcode in Italy! Model number will be on same lable. Mod:
Jun 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
Dec 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De GO PATS
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
