Question about HP Color LaserJet 2600n Printer
HP2600n ? soft grainy texture printing in background
We had this problem once before, it was even on the troubleshooting list as, "Toner appears around the printed characters". Last time, it ended up that HP just told us to exchange it, but now we don't have that option. The new printer we exchanged it for is doing the same thing.
I remember being told by HP support to clean the ETB many times and have done so, but the problem does not seem to go away. Any ideas of other things to try???
"inside the image tranfer belt unit,there have 4 rollers ,just clean both end of roller and also the contact metal spring clean that and bend it little bit make sure it contact perfect, should be take care your problem"
I apologize, I am a designer and have never done any maintenance like you are talking, how do I do this, is there anywhere that provides diagrams or steps of how to take the rollers out? What do I clean them with?
  • HP Master
  • 990 Answers
Inside the image tranfer belt unit,there have 4 rollers ,just clean both end of roller and also the contact metal spring clean that and bend it little bit make sure it contact perfect, should be take care your problem
Posted on Dec 08, 2008
The ice cream is granular in texture-
I actually own the same ice cream maker, and it has made some very good ice cream for me. The most likely causes of grainy ice cream are too short of a time in the machine or recipes with incorrect proportions of water, fat, and sugar.
Firstly, make sure that you are using one of the recipes provided in the maker's user manual, or a different recipe from another source which says that it works with all ice cream makers. Following these recipes will ensure that your ice cream base (the liquid that you pour into the machine) is the correct consistency and composition for freezing. For example, too much sugar could cause improper freezing by oversaturating the solution, or too much fat (or fat incorporated incorrectly) could cause the mixture to become grainy or separate.
If you are using a recipe that calls for eggs, make sure that you mix them with the listed amount of sugar thoroughly before tempering them with the hot cream/milk solution. Additionally, make sure that you only pour a little bit (quarter - half cup) of the solution into the egg mixture at first, stirring thoroughly, before adding the rest. This assures that the eggs do not curdle when heated, which could cause a grainy texture.
Finally, make sure that you are freezing the mixer bowl overnight, using chilled ingredients, and allowing the machine to run for the full 20-25 minutes. The ice cream should be a bit softer than the consistency of soft-serve when you take it out of the machine - easily scoopable with a spatula. If you like it firmer, an 8 to 48 hour freezer session will greatly improve the texture in my opinion.
Hope this helps!
Mar 19, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Prints with lines to the right margin of the page. How can this be corrected?
This can depend on if they are white or black lines and if you can feel a texture on the paper. Most often the cause is a bad toner cartridge. If you are using generic toner cartridges, I would suggest trying a new HP one instead to see if it clears up. If you feel a deep texture to it, the fusing unit may be wearing out and need to be replaced.
Feb 03, 2011 | HP Laserjet P4015x Printer
Printed images are grainy? especially the skins. any solution
This could be caused by a couple of things. The first one is the toner cartridge. A defective or low toner cartridge can cause light "grainy" looking copies. If you have a spare toner cartridge try that first. The second possibility is dirty scanner optics. The scanner bar that lights up under the glass and moves back and forth has 3 mirrors on it. When they get dirty is causes your scanned image (before it gets copied) to appear light and patchy looking. The glass must be removed by removing the 4 screws on the left hand side. Then the scanner can be pulled out and the 3 mirrors cleaned. If you have the machine hooked up to a computer to be able to print then these mirrors will NOT affect PC prints. If PC prints are grainy then that would point to the toner. The dirty mirrors will only effect the copies.
Good Luck and Thank You for using Fixya.
We are having a contest this month that is based on positive testimonials. If my solution is helpful please leave a short testimonial for me.
Oct 06, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Picture quality not good on print outs has a grainy texture and is missing dots of ink
please replace toner with new one & original. hope print will be clear & fresh.
Oct 06, 2009 | Samsung CLP 300 Laser Printer
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
Photo print quality Canon i860
You might be running low on toner or ink. In this case check out the ink/toner capacity left. it might even be a faulty cartridge if bought new, or a faulty printer, but it doesn't sound like it.
Dec 27, 2008 | Canon i860 InkJet Photo Printer
Dark background on Dell 1700 printing
Faulty (or wrongly) remanufactured cartridges can produce a 'background' to a print, which can be even across the page or have a mottled effect.
Do a printer self test page (press the arrow button).
put the old toner cartridge back in and do the same.
Does the background show with the old cartridge ?
If it does, its a drum unit problem, if not its a toner cartridge problem, and that should be under warranty if you've just replaced it.
Dec 06, 2008 | Dell 1700n Laser Printer
HP2600n color printing not registering
Looks like theres a problem with the color ragistration.
I would calibrate the printer. Heres how;
  1. Go to "System Setup" on the display. Press Select.
  2. Go to "Print Quality". Press Select.
  3. Go to "Calibrate Color". Press Select.
  4. Go to "Calibrate Now''. Press Select.
  5. Press Select again to confirm Calibrate Now.
This will calibrate the printer and should eliminate the color registration problem you are having.
Nov 11, 2008 | HP Color LaserJet 2600n Printer
Problem with phaser
Phaser 2135 Printer: Resolving dirty looking background or gray haze
Description: Tiny speckles of toner scattered all over the page, even in areas of the page that should be blank.
  1. Make sure the media being used is supported by the Phaser 2135 printer.
  2. Inspect imaging drums for any signs of leakage or excess toner that could be falling onto the print as it travels though the printer. Any leaking imaging drums should be replaced.
  3. Verify environmental conditions. See article Dealing with humidity, humidifiers. If the environmental conditions are not within the specified range, the printer should be moved before trying to troubleshoot the cause to the background toner.
  4. Determine if any of the imaging drums were exposed to light for an extended period of time (more than 10 minutes). If so, then Replace the imaging drum. (Xerox is not responsible for any imaging drums that have been damaged by over exposure to light.)
Additional Recommendations:
Background toner may increase, if printing occurs at temperatures towards the higher end of the specified operating temperature range. For this reason, it is recommended that the printer be moved to another area if at all possible.
In addition, very smooth media types such as glossy; allow toner to more easily scatter about the page prior to becoming fused. Try using a less smooth media if at all possible.
Feb 08, 2008 | Xerox Phaser 2135N Laser Printer
Printer prints documents with gray-shaded background
check the mode of printer is i grayscale or in colour mode. bye
Jan 30, 2007 | Dell 922 All-In-One InkJet Printer
HP Color LaserJet 2600n Printer Logo
155 people viewed this question
Ben Johnson
