WHEN I PRINT A PHOTO THE FACES ARE ALL SMUDGED
  • Anonymous Mar 13, 2009
    Same thing I'm experiencing with my RX560 tried cleaning it manually and with head cleaning, the bottom is fine its just the top that gets smudged
    President:
  • Office Equip... Master
  • 990 Answers
1, power on the printer
2, open the cover let ink cartridge moved to the center
3, unplug the power cord
4,use Q-tip to clean up the cartridge seat
Posted on Dec 08, 2008
Orange faces
Under printer driver properties clean the print head.
Use only genuine ink crg.
Use only genuine photo paper.
Jul 02, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Problem with black print head only.
clean by injection siringe, if not solved you need to replace print head
Jan 07, 2010 | Epson Stylus Photo R300 InkJet Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Epson stylus photo 890 printer (5 years old)has
Do a cleaning several times. If that doesn't do it, then it is time to get a new printer. They are cheap enough and will be cheaper than bringing it to the repair shop.
Apr 22, 2009 | Epson Stylus CX9400 Photo Printer
Photos print wet and smudged
all the dx /cx range do this when printed on the high quality settings you just have to let ink dry about half hour or use a lower seting when you print on gloss paper hope this helps
Dec 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Photos are all smudged as if they were getting too much ink
From my own experience, you may not be using inkjet photo paper. If you have a photo printer or printer dock, try not to use the same photo paper on the all-in-one as they are not compatible. Try using any Kodak Premium/Ultra Premium photo paper to resolve this.
Jun 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
jasbo
jasbo
