Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
Hard Drive not picking up speed.
Pc does not start up, hard drive not picking up revs. Keep stopping then restarting every one or two seconds.
  • 1 more comment
  • Trev Box Feb 24, 2007
    Thanks zeusfaber.
    Will try it on another PC, though I have already tried another hard drive on the same cabling, which worked OK.
    I would like to retrieve some of the Data though which I hadn't backed up for a few days.
    Coffin
  • Trev Box Feb 25, 2007
    Thanks tomj23
    Not worth that type of big Busks.
    Sill, I can never resist a challenge,so I'll play around with it and see how far I get.
    I'll let you know if I get anywhere.
    Coffin.
  • yogu Nov 19, 2007
    my hard disk is samsung sp0802n.when i plug up my hard disk to mother board it does't start but mother board works fine on another hard disk.
    there is important data on my hard isk how i repair my hard disk
    suggest the solution
  • 624 Answers
Coffin, I if another drive works in the same PC then the problem is probably the physical drive itself. If you have data you need your best chance is to install a new drive in your PC, install and configure a new copy of your operating system. Once you have that done then take your old drive and connect it to your PC as a "slave" drive. If the drive will spin up then you might be able to pull the data off. I suspect that if the drive starts up then spins down in a continuous pattern you have a problem with the drives spindle motor or its controlling electronics and that is beyond the repair abilities of most users. If the data is worth lots to you it can be sent to a commercial data recovery specialist. Be prepared since these folks are pricy. Another alternative if the data isn't very important to spend big bucks on is replacing parts on the hard drive. Depending on the part this is very risky and not usually a viable option unless you happen to have an IDENTICLE drive, time and the ability to risk the data. Let us know how things go and please don't forget to rate this post.
Posted on Feb 24, 2007
  • 247 Answers
You might try the hard drive in a different PC, just to check you haven't got a duff power supply, but in all liklihood, you're going to have to buy a new hard drive and restore from your backup. A.
2003 Rav 4 periodically stalls at low idle, intersections
Start with the throttle body. I use brake clean and a toothbrush. Clean the plate and were it sits. Wouldn't hurt to spray down the MAF sensor, if it has one. Once you do it, it will take a few seconds to start. Once started, rev it up and spray inside the throttle. Keep it running. Most times this is a $4 fix.
Aug 20, 2016 | Cars & Trucks
Blue screen error plus blank start up screens but the start up sound can be heard.
Have you changed any BIOS settings? I would open your BIOS menu and make sure it is set to "AHCI"
Aug 21, 2012 | Lenovo IdeaPad U550 Notebook
I can't reach the files on my hard Disc. the pc reconised it but it doesn't work. it tell to format all. can I do something else to keep my files?
If it tells you to format it then that means that the files are corrupted. This can happen due to removing the usb hard drive without stopping the hard drive first. To stop it first you need to
1. Right click on the new icon that if you rollover it says removeable storage device
2. click stop
3. Then click stop and choose the device that you want to stop and hit stop again
You can use a program such as TestDisk to try and recover your files.
Here is TestDisk:
http://www.cgsecurity.org/wiki/TestDisk_Download
May 10, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
LaCie Hard Disk by Neil Poulton keeps restarting
it souns like a PSU issue make sure ALL connections that attach to your hard drive are secure or replace them including IDE,SATA even replace PSU with a heavy duty one
hope this helps
Jul 28, 2010 | Computers & Internet
WHEN DRIVING AND THE TRANS NEEDS TO SHIFT ON MY 2005 VW JETTA 2.5-5 NEW STYLE THE RPM'S REV UP BRIEFLY THEN THE TRANS WILL SHIFT THE SHIFTING IS SMOOTH BUT THE HIGH RPMS WORRY ME.
when vw started to use the computer controlled gearbox system a criticism was the shift was very harsh,to counter this they made it rev slightly before changing.so that you know the system, try this out....without touching the gas.....put it in d and let the car accelerate to its max speed,stop,then use 1/3rd of gas (keep your foot still)and let it do the same...stop,then,if safe,put your foot to the floor,hard, notice when the car changes gear(revs/speed)then if you drive,only using the first1/3rd of the gas,the cars change pattern will alter to suit.......wierd it is.....
Jul 20, 2010 | 2005 Volkswagen Jetta
My windows explorer stops and restarts please help me to solve the same
It's possible that it's a hardware problem or your computer is infected by a computer virus. Does it restart when you see the windows XP logo or when you are in the desktop? or Does it restart before seeing the windows xp welcome screen? Since this is a laptop it may be hard for you to reseat some of the internal devices inside in your laptop so we could start isolating the issue from the hardware and to the software.
First try to power cycle it, turn off your laptop remove the battery, any external connection like external mouse, external hard drive and monitor and press the power button for 15 seconds after that put the battery in and turn it back on without the external devices plugged in. (if it turned on without a problem that's good-possible that one of the external devices are causing it to keep on restarting, to isolate it you can just put the external devices one-by-one and start the computer, if it start occuring you know who is causing the problem)
If you can disassemble your laptop you can try to remove the hard drive, then turn on your computer, if your computer didn't restart that means that the problem is with you hard drive, possible that the software installed in it is faulty or the hard drive itself (try plugging it back in properly let's see if it'll work, if not, you may need to buy a new hard drive or before buying one, you can try to plug your hard drive to a different computer (acting like an external hard drive) and backup all your important files and reformat that hard drive, after reformatting it you can try to plug it to your laptop again. (if that hard drive is not detected to another computer meaning that it's faulty)
If that didn't resolve the problem, you can try to reseat the memory testing each memory chip and slots, processor.
Hope this help.
Jan 11, 2010 | Acer Extensa 4620-6402 Notebook
HP530 shuts down within 15 seconds as it loads XP
Probabpy an XP problem, start XP in safe mode (press F8) as it is loading.
If it runs then it is probably a driver problem. Try restarting in the last good configuration. Keep posting until the problem is resolved.
Aug 17, 2009 | HP Computers & Internet
97' Jeep Cherokee revving problem...
There are several reasons this can happen. First check all vacuum lines to make sure they are connected and unbroken. Second, have a code test done to see if anything has registered in the computer. There are also individual component tests you can do but what I suggested is a good place to begin.
Jun 03, 2009 | 1997 Jeep Cherokee
When i boot up i get a message that my hard disk failure is immenent is there anyway to repair this problem
if you get a "Disk Controller Error" error messages that may occur before Windows XP or Windows 2000 is started. Imminent Hard Disk Failure This error may appear when the hard drive detects that it will fail or stop working sometime soon.
Backup Data Before Proceeding Although the notebook may continue to start Windows after displaying the message, it is advisable that you immediately backup your personal data from the PC by copying it to a Network Drive, CD, DVD or USB storage device. After completing the backup, use one of the following methods to resolve the error. Step 1: Test the Hard Drive Use the steps below to test the hard drive in a Notebook PC using the HP Hard Drive Self Test.
  1. Plug the AC Adapter into the Notebook PC.
  2. Press and hold the Power button for 5 Seconds to turn off the PC.
  3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
  4. After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
  5. Select Hard Drive Self Test
  6. Press the Enter key to start the test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed. If any test fails , order a replacement hard drive. If all of the tests pass, the hard drive is not damaged.
If all tests pass , press the power button to restart the PC. The error was most likely a result of a shock to the PC triggering a SMART error from the Hard Drive. Since the Notebook PC passed the Hard Drive Test, it is safe to use.
Mar 07, 2009 | Acer Aspire 3680 Laptop
Notebook won't start
press the key F1 or F2 or F10 or DELETE when you try to restart your computer before 5 seconds that will open the BIOS page so go to boot order and change it instead of start with cd flopy hard drive put the hard drive first save it and restart the computer it have to work good un less there is a problem with your hard drive or windows software if that is the case restart the computer and press F8 before 5 seconds and you'll see black page with the next options last know good config and save mode click on last an then restart the computer if does not work try save mode of you can acces tue hard drive that means bad windows software if not bad hard drive
Jan 02, 2008 | HP Pavilion zd8000 Notebook
Samsung SpinPoint P80 SP0802N 80 GB Hard Drive Logo
78 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
