Question about Sirius Satellite Radio Receiver
Sirius radio add on in my car keeps cutting out - says "it's look
Say's "it's looking for signal". Is there interference with cellphone towers? I've tried to pinpoint the problem - weather, cloud cover, rain, clear sky. Nothing is consistent. On a recent road trip we noticed when near cell phone towers we could guarantee the signal would be lost. What can we do about this?
THE CORD IS THE PROBLEM ,CALL THEM&DEMAND ANOTHER ONE.
Posted on Dec 17, 2008
The radio keeps cutting out. I hear a squeal as if the phone is turning on and it cuts out for a few seconds then start again. ? as if it is looking for a radio signal?
It sounds like your radio receiver or even antennae may not be properly shielded or are failing. Here is a great website link that helped me troubleshoot a similar issue .
Identifying and suppressing radio interference
Please let me know here if it helped.
Good Luck!
Dec 07, 2015 | OEM 2008 Porsche Cayenne Radio / CD Player...
Help Audiovox Onyx
Its because of the tall buildings and all the power around you breaking the signals.
Apr 23, 2013 | Audiovox Xm Onyx Sirius Xm Satellite Radio...
Why do i only get 184 and no other stations
You need to put the van out in the open with the radio "ON" (car off) and leave it on CH184. Call the 800 (855-whatever) number and ask them to send a "refresh signal" to your radio after you give them the Serial number from channel 0. Wait about 20 minutes, you should eventually see an "updating" message on the display; then see if you get channel 5; if so, then you're good. Again. Car off; radio power on, van out in the open; call Sirius and ask for a 'refresh signal' for your serial number. You'll have to call during the day when they have customer service reps available. Good luck; call on your cellphone and they can walk you thru these same steps.
Dec 02, 2012 | Sirius Satellite Radio Receiver
Sirius truck antenna stopped working
The truck antennas can go bad. It could be the cable though. You can replace either part at www.tss-radio.com
May 20, 2012 | Sirius Satellite Radio Receiver
Tone in sirius radio using aux. input
Do you have a thicker audio cable you can use? It might cut down on the interference that way.
Mar 16, 2009 | Sirius Satellite Radio Receiver
We have a Peavey RQ4332C that seems to work well with direct feeds but when using wireless anything, sparatically, we get interruption and distortion in the system. Help? is this the board or outside...
Usually this is caused by a cellphone in the area. The cellphones send a signal to the cell tower ever few seconds, when they do that, it makes it sound like the wireless mike is losing its battery, when in fact, it is the cellphone interfering with the signal. A simple test would be to power up the system when you can verify there are no cellphones turned on and try the wireless system. Then turn the cellphone on and repeat the scenario.
Sep 15, 2008 | Audio Players & Recorders
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
04 Santa Fe Issues
I would look for a ground that is inadequate.
If any part of this is operating essentially without shielding due to a bad ground, then cell towers, a radio or TV station transmitter, CBs, land mobile radio, amateur radio - any of these can inject enough signal to drive modern electronics completely bananas.
The onboard electronics used for just about everything that is remotely controlled by switches generates a ton of digital garbage and can interfere with anything.
The kind of problem you are experiencing started when we stopped using vacuum tubes 50 years ago operating at high voltages and started using semiconductors that use much lower voltages.
A tech with a common multimeter should be able to locate the missing ground connection without too much trouble.
Jun 10, 2008 | 2004 Hyundai Santa Fe
Sirius sportster sp-tk1, always displays "acquiring signal"
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
Sirius Satellite Radio Receiver Logo
206 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
