Question about Panasonic PT-53WX42 53" Rear Projection Television
Green convergence on Panasonic PT-53WX42 is not ligning up...
I've had my Panasonic PT-53WX42F for 5 years now and first noticed the problem about 2 years ago. The problem has gotten steadily worse and is now at a point where I can't stand it. The green on the left and right sides of the screen are "askew".
The green on this set can be adjusted vertically and horizontally by aligning green lines with marks on the top, left, bottom, and right sides of the screen frame. The problem is that this green "+" sign seems to be "rotated" slightly counter clock wise so that it is impossible to align correctly. The end of the green horizontal line is below the mark on the left edge of the screen frame and above the mark on the right side. The vertical line is left of the mark on the top of the screen and right of the mark on the bottom.
The 2 repair techs I spoke with on the phone told me that the convergence IC's probably need to be replaced and that it will cost me $400 to $500+. I just want to absolutely sure before I attempt to fix the problem myself. The problem didn't just appear suddenly. This seems to to me like something just got out of alignment in there, possibly due to the vibration of my sound system.
Another thing I'm wondering about is how to clean the inside of the screen. A couple spiders got trapped in there somehow and I can see what looks like bits of stuff hanging from their webs.
  • john_aust252 Dec 27, 2008
    Thanks for the reply! =)
    Do you know where I can download the service manual or can you email it to me? I figured it was something like the skew you mentioned but I don't know how to enter the service mode on my model.
  • john_aust252 Dec 30, 2008
    john.austin@verizon.net - sorry I can't believe I neglected to post it! Thanks again. =)
Does not sound like the chips are bad.
What you need to adjust is "SKEW". You need to enter "service Mode" then go into "Coarse Convergence". Skew can be adjusted for all 3 colors. Unless you have the service manual, these corrections should not be attempted.
To clean the INSIDE of the screen, you really have to disassemble the TV. Remove all the screws that hold the "back" ( the piece with the mirror) to the front (screen) assembly.
The screen can be cleaned with a solution of diluted isopropyl alcohol, no more than a 50% solution. Drugstores will carry it, but it might be 70%-90%. Just dilute with distilled water (not tap water as it contains minerals). Personally I have used 70% with no ill side effects but 50% is recommended.
Posted on Dec 21, 2008
  • black318is
    black318is Dec 27, 2008
    I have the manual in PDF form (zipped to reduce size). It is 15.2 megs in size. Not sure if most email boxes can accept that or not. Post your email address and I can try to send it.
  • black318is
    black318is Dec 30, 2008
    Like I thought....Little to large to email.....Also not sure if this is the correct manual I have....It doesn't list our exact model, but other sites reference this as the correct one....Here is a link to download:
    http://webgraphx.com/panny/
    I will leave this online for a few days, so grab it while you can
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Need the right Convergence ICs number for Panasonic pt-53wx42f is the STK392-110 the right one and I need 2 right
i just repaired one of these sets today, yes, they are 392-110's - make sure to get genuine Sanyo ic's and not generic counterfiet ebay ones.
Dec 17, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
Aug 05, 2008 | Panasonic PT-53WX42 53" Rear Projection...
RESISTORS
The value of those resistors is 0.27 ohms 5% 1 watt.
Click here to find the resistors.
Jul 21, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Resistor
electronix.com or matelectronic.com should have that resistor. Be sure to specify flame resistant 5% tolerance that is a convergence resistor so it needs to be flameproof and install it up off the board like the origional was.
Feb 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PT-53WX42F
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 26, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX42F Picture Problem. Color Distortion.
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Green horizontal deflection
Change both STK convergence IC's for reliability. They amplify/control both horiz and vertical. re-align after replacement.Locate them on the largest heat sink in your set!
Sep 26, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
176 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
