Question about iRiver H10 MP3 Player
Cannot reset After repeatedly following the instructions to reset my device, it still will not reset. The instructions are to remove the battery then reconnect it, and turn the player on. This is just not working. What can be wrong and what should I do now?
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
SOURCE:
Error message "turn power off and on again" I did this and it did not work.
Performing a manual power reset (If your camera does not have reset button and initialize function)
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jan 07, 2014 | Sony Dsc-s2000 Cyber-shot Digital Camera...
Bluetooth connection issues
There are several things to try:
Remove and then reinstall the device:
Click the Start Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
Select the device that's not working, and then click Remove.
Click Add, press the reset button on the device
(or make it discoverable following the manufacturer's instructions), select the My device is set up and ready to be found check box, and then click Next.
If the device is not found, repeat the previous step.
When the device is found, select it, and then click Next.
Follow the rest of the instructions in the wizard.
Make sure the device is turned on and that the batteries don't need to be replaced.
Make sure the Bluetooth adapter for your computer is attached and turned on, and that the device is turned on and discoverable.
If you're not sure how to turn on discoverability, read the instructions that came with the device or check the manufacturer's website.
Make sure that you installed the device using the correct program. If not, reinstall the device.
For a printer, follow these steps:
Open the Add Printer wizard by clicking the Start Control Panel, clicking Hardware and Sound, clicking Printers, and then clicking Add a printer.
For a mobile phone, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Click Add.
For a keyboard or mouse, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Connect a wired keyboard or mouse to your computer.
Click Add.
The device might be out of range of your computer, or too close.
Try moving it closer or a little farther from your computer.
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.html
Runs in the background, and monitors the activity of Bluetooth devices around you
Oct 06, 2012 | HP Pavilion dv8000z Notebook
Cannot clear zone, how to factory reset SC-100 skylink
There is no factory reset for the zones. User must follow instructions in the manual to clear all the devices in a zone.
Search the manual for "ADVANCED PROGRAMMING". Then look for "TO CLEAR A ZONE". Follow the instructions to clear a zone. Note that zones 1, 2, 3, and 4 are for sensors and zone 5 is for remotes. Each zone can accommodate a maximum of six devices.
Each command can erase one zone. If more than one zone is to be erased, repeat the command for each zone.
Jul 26, 2012 | Skylink Group Skylink Sc-100 Security...
Lg ally touch screen stopped working
Likely a defective touchscreen, may be software related.
1. Remove Battery, Attempt to Restart phone. repeat at least twice.
2. Perform a hard/factory reset. a. for most phones the go into your phones setting and look for a reset option. b. Follow the prompt to reset your phone to factory settings. c. Make sure to back up all your data
3. Contact a service representative of your carrier or take the device into your carriers store, most of the time they will recommend doing a hard reset as shown above, they will NOT replace a device without doing a factory reset on the phone.
all goes well they'll likely replace your handset,
Jun 16, 2011 | Cell Phones
My LG AX275 I cannot hear anything when i try to make a call. even my ringtones i cannot hear. i set all the volumns to high. when i turn the phone on/off it makes a little sound but thats it.
Sounds like a defective Sound chip in your device. I suggest taking the following actions:
2. Perform a hard/factory reset. a. for most phones the go into your phones setting and look for a reset option. b. Follow the prompt to reset your phone to factory settings. c. Make sure to back up all you data
Good Luck!
Jun 16, 2011 | LG ALLTEL AX275 Cellular Phone
Hello i forgot my germin nuvi 350 gps password can you please help me how to reset it Plzz
To perform a Master Reset on the nuvi 300 series, follow these steps:
  1. Start with the device OFF and unplugged from the power source.
  2. Use your index finger to press and hold the top right corner of the touchscreen.
  3. Power the device ON while continuing to press and hold your finger to the top right corner of the touchscreen.
  4. After the device powers ON, release the power button. Then you will see the message: Do you really want to erase all user data?*
  5. When this message displays, remove your finger from the top right of the touchscreen and touch Yes.
  6. The device will now go through the Reset.
  7. Follow the onscreen instructions to set up your nuvi.
After the nuvi is set up, if indoors, please go outside to allow the device to acquire the satellite information. Ensure that the device has a clear line-of-sight with the sky.
*If this message does not appear when using the top right corner of the touchscreen, please repeat these steps using the bottom right corner of the touchscreen.
May 30, 2011 | Garmin nuvi 350 GPS Receiver
Hvb error on blackberry bold 2 ...not able to re boot
Hi, you can try and reset the phone with the following instructions below. worked for me.
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Jan 25, 2011 | Cell Phones
Handset shows abort exception reset how to reset this.
"Perform a hard reset on the handheld by pressing the Alt key + the Cap key + the Del key, 2 times"
To specifically answer your question, a hard reset is simple a removal of the battery and reinserting it.
However, you wish to do more than that, you want to wipe the device.
You will need to use JL_Cmder to wipe the device and subsequently load the OS to the device. Follow the instructions here:
http://www.blackberryfaq.com/index.php/How_do_I_wipe_the_BlackBerry_using_Jl_Cmder%3F
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 10, 2010 | RIM BlackBerry 6230 Handheld
Htc tytn 2 problem
Try to hard reset your device. Your device will return to its factory defaults. Your device's user manual tells how to do it. Just in case you don't have it, press and hold both softkeys. Whilst keeping them pressed, briefly press the reset pin with the stylus pen. Release the keys as further instructions come up on-screen. Just follow them.
Hope your device comes back to life soon.
Cheers! Carlos
Apr 27, 2010 | HTC PPC-6800 Smartphone
Problem with Bluetooth And Special button on top & Right (around keyboard)
  • Remove and then reinstall the device:
    1. Click the Start button , click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
    2. Select the device that's not working, and then click Remove.
    3. Click Add, press the reset button on the device (or make it discoverable following the manufacturer's instructions), select the My device is set up and ready to be found check box, and then click Next.
    4. If the device is not found, repeat the previous step. When the device is found, select it, and then click Next.
    5. Follow the rest of the instructions in the wizard.
  • Aug 18, 2008 | Acer Aspire 5630 Notebook
    iRiver H10 MP3 Player Logo
    Top iRiver Audio Players & Recorders Experts
    Steven Wander
    Steven Wander
    Peter Dragonetti
    Shawn DuRee
    Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
