Nikon Coolscan 9000 ED can not be recognized by computer
Having new Nikon Coolscan 9000 ED with Firewire interface.
All cables and IEEE 1394 card are supplied with the scanner.
OS is Windows XP Pro En SP3, MB is Asus Maximum Formula, 3Gb RAM, all fresh MB drivers are installed.
All actions are according to the manual: 1) install the card, 2) install the software + 2 updates, 3) connect and turn on the scanner, 4) start Nikon Scan.
Having the message: ''Nikon Scan can not find any active devices''.
Coolscan 9000 LED is blinking for an infinite time, and no self-testing sounds are heard.
In Device manager, I can not find Coolscan 9000. In the same time, IEEE 1394 card is present and displayed without error signs.
When switched on being disconnected, self-testing is OK and LED stops blinking for 1-2 min and lights continuously. When I connect the scanner after that, I again can not see it in Device manager and get the same error from Nikon Scan.
I've tried to 1) reinstall Nikon Scan, 2) reinstall Windows to SP1, SP2 and SP3, and do the setup procedure above -- the error is reproducing.
Please help to solve this problem!
    Welcome Back:
    Visited the website for 2 consecutive days.
I am having the exact same problem...cannot get the Coolscan 9000 to show up in Device Manager. One thing I did try (to no avail) was to run the regsweeper.exe file that comes with the Nikon scan disk. It clears your registry when you reinstall. It still did not work though so I have a lovely "shoebox" sitting next to my computer that is worthless!
Posted on Feb 02, 2010
How do I connect my M-Audio Projectmix I/O to my PC running Windows 7 x64 via TI Firewire card? PC is not recognizing Projectmix.
Did you change the IEEE 1394 Host Controller to a legacy driver or did you just add one? You have to change IEEE 1394 to the 1394 OHCI Compliant Host Controller, specifically.
Did "Firewire Enabler" get installed in the Start menu? If so, give it a try. Make sure to download the latest PMI/O update from M-Adio if you haven't already.
Also, the old computer might of had a different PCI card. I remember there being compatibility issues with PMI/O and Express cards. Check the card type. There might be a firmware, patch or an update to fix the issues.
If the card is incompatible, just switch out with the other (if you still have it).
If the issue still exists, try Klinke's MCU plugin. It should work if nothing else. Maybe check for ASIO Driver issues. Other than that, it would have to be hardware or bad cables.
Aug 15, 2016 | M-Audio ProjectMix I/O Control...
I need a hookup layout for audiofire4 connecting to a Roland XP 80 and to a computer
if your computer has a Firewire (IEEE 1394) port, you can use a Firewire cable to connect one of the AudioFire4's Firewire ports to the computer's Firewire port, then hook up your XP80 to the MIDI ports on the AudioFire4. Connect MIDI Out to MIDI In.
Sep 07, 2013 | Echo AudioFire4 Portable FireWire Audio...
PC stopped recognizing Nikon Coolscan 8000
Ah Firewire ;) Have you tried reinstalling the firewire card drivers? Make sure you press the "delete driver" button if there is one/
Jun 17, 2009 | Nikon COOLSCAN 5000 ED Film Scanner
Do I need a fire wire card for PC
Hi a firewire input is different from an 1394 port. For the laptop you can buy an firewire interface.
Regards,
Rob NL
Apr 16, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Nikon Coolscan 9000 not recognized by XP computer anymore....
I read and would like to thank, the person who mentioned this as a solution. It was stated that if you have more than one firewire on your computer, when you open the Nikon, both signals, or whatever happens in computerland, don't connect. Upon removing the drive in the other firewire, Nikon clicks in everytime. Answer: have only ONE active firewire at a time. You may need to unplug the cable to the scanner and reconnect. But that's it. I've not had any problems since
Jun 09, 2008 | Nikon CoolScan 9000 ED Film Scanner
USB cable from scanner to new Dell Optiplex 755
If you look carefully at the cable, you will notice it is a firewire cable (IEEE1394), not USB. You will need a firewire interface on your computer to use the Nikon scanner. It will not work with a USB port.
Jan 02, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Samsung SC-D363 won't load to my computer
If you are trying to move video that is stored on TAPE, you need to get a Firewire cable. Using the USB cable, you can only transfer photos and video that is stored on the Memory Stick Pro memory card (user-supplied). The Firewire cable has a standard IEEE-1394 male connector on the computer end and a mini IEEE-1394 male connector on the camera end. If you don't have a Firewire interface on your computer, you will need to get one. Good luck.
Nov 21, 2006 | Samsung SC-D363 Mini DV Digital Camcorder
Can I use Firewire to transfer video?
Your computer must be equipped with an IEEE 1394 (Firewire) interface and video capture software. Provided you have both of these, follow the directions below. To connect your digital camcorder to your computer using IEEE1394, follow these steps: 1. Connect the IEEE 1394 interface on your camcorder to the IEEE 1394 interface on your computer. 2. Turn on your computer. 3. Turn on your camcorder. 4. Start the video capture software on the computer. Image capture should begin provided the computer hardware and software are configured correctly. If image capture does not begin, you must consult the computer or capture card manufacturer for assistance. Note: If you don't have an IEEE 1394 interface on your computer, you can buy an IEEE 1394 pci card at your local computer store that will work with most current computers.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
593 people viewed this question
k24674
jasbo
jasbo
