Question about Motorola Mobility MING A1200
My phone is only powering
I recently purchased the motorola ming. It functioned fine until now, it is not powering up when it is off the charger even on a full battery. what should I do?
    Problem Solver:
  • 3 Answers
It needs a new battery and transceiver board...
Posted on Dec 10, 2008
Motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Feb 05, 2010 | Motorola Mobility RAZR2 V9m
No charger recognition
Hopefully you have damaged the charger and not the phone. Go to Best Buy or Radio Shack and attempt to plug in another charger, if that works, just purchase the charger. If not, you have damaged the phone itself and can only be fixed by an authorized repair center!
Apr 19, 2009 | Lands Phones
Motorola i880 white screen flashes i880 won't charge
the i880 & the i885 needs a quality charger, if you get a original Motorola charger IT WILL WORK. There are some aftermarkets that will work, but not many.
Mar 24, 2009 | Motorola Mobility i880 Cellular Phone
Can't bond Samsung bluetooth(WEP 200)with my Motorola A1200 Ming
Try this (from the manual)
2 Press and hold the Multi-Function button until
the indicator light turns on in blue
(approximately 8 seconds).
Oct 31, 2008 | Motorola Mobility MING A1200
Motorola Ming-SD Memory Card...
Hi, this is mayank , i would like to tell u that motorola ming can only support only 2 GB of memory and it is hard to get the througput from 4 gb SD card... kindly replace that or get the new one.......
Oct 14, 2008 | Motorola Mobility MING A1200
Download mobile games motorola A1200
As i had told earlier there is no specifc site that provides games for the moto ming as this phone is a PDA , not aimed at gaming . There are only few games that work on it and with full or partial functionality
http://www.getjar.com/software/Motorola/A1200
http://www.mobilerated.com/motorola-a1200-ming-games.html
Apr 14, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
Ming Vista Phone tools
yes you can update u r phone tools online or you can download the latest varsion that supports vista from net
Apr 04, 2008 | Motorola Mobility MING A1200
Motorola A1200 Problem
Easy step by step solution!
Hey guys had the same, Try this solution before buying a new battery/charging cable (it might not be the problem):
I did these steps after playing around with it for awhile and am at the stage where my phone turns on fully and says "Battery Charging" when plugged into the charger. It is now charging normally again... Finally! (I had the flashing moto logo too when charger plugged in) I believe this problem occurs because the battery is completely drained and is unable to turn on to charge bcuz the phone needs to be on to be charged, happened to me because i left it in a jacket pocket and forgot about it for weeks. Anyways...
1. You need a USB data cable for it, it should have come with the phone, if not than any USB data cable that fits the phone's charging slot should work (charge cable for the ps3 controller will work or maybe a cable from a digital camera with the same end)
2. Connect the phone to your computer via the USB cable and a USB port that works. Make sure it's plugged in and leave it (even if nothing happens and the screen on the phone is still blank). Although the screen is black, the phone is still charging via your computer (it's just too low on battery to produce the light on the display screen to load up your phone).
3. This might take anywhere between 15 and 45 minutes so be patient and leave it plugged in, beats buying a battery of charger with your money for something that can be solved for free.
4. At some point your computer will make the usual processing noises signalling that it is finally recognizing the phone as a usb device and shortly after your ming's screen will turn on stating that the battery is charging. Success! One of two things will happen, if you have previously installed the ming's drivers to your pc it will just recognize the phone. If you are like me and do not have the drivers installed, you may choose to do so via the cd that came with the phone or just not do it at all.
5. If you want to just charge it via the computer then congrats, your job is done, just leave it plugged in and wait until it is fully charged. If you wish to switch to your regular outlet charger please proceed to step 6.
6. At this point drivers installed or not, either safely remove device from the computer or just unplugg it. Now return your phone to your usual outlet charger making sure its connected. When plugged in you'll notice the moto logo appear (no longer flashing). After about 5 seconds that logo will disappear. At this time flip open the phone. The usual turn on sequence will play out and it will now load up with the battery charging screen similar to the screen from when it was plugged into the computer. Congratulations your phone should be back to normal now.
NOTE: This charge will take longer than your normal charging time but that's just for this time since your battery is super low it will be back to normal after that. Also if this did not work for your phone then now is the time to see if the charger/phone/battery is the problem.
So I hope this helps you out and eases your state of panic. I hope I saved you guys some money with this solution and that your mings are up and running again. I know i was pretty content when the problem was fixed. Please reply with any comments, questions or concerns you may have. Enjoy your once again working mings.
Jan 24, 2008 | Motorola Mobility MING A1200
MOTO MING A 1200 VISTA DRIVERS REG.
Recently i have purchased a Moto ming A1200 (second hand) i dont have the driver CD for this mobile from where will i get driver CD for this phone for connecting it to window vista basic PC
Oct 31, 2007 | Motorola Mobility MING A1200
MOtorola Ming keeps shutting on and off
check the batery of h/s, or contact motorola care center
Oct 14, 2007 | Motorola Mobility MING A1200
Motorola Mobility MING A1200 Logo
60 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
