Question about LG Studioworks E700S 17" CRT Monitor
My screen becomes yellowish..
Recently my monitor screen become yellow while working. and i have checked the cables,but every pins are in good statea. help me out
  • 3 Answers
If all software setting done perfectly but till color problem in your monitor, then need to call monitor technician. It may occur from crt neck base loose contact or bad contact. need to replace new one.
Posted on Feb 22, 2014
    Novelist:
    Champion:
  • 202 Answers
Have you checked you monitor settings on the monitor? You may try setting you monitor the factory default and then re-adjust from there. Have you tried upgrading your vidoecard drivers? I would 1) Check actual setting on the monitor. 2) Make sure you are using the proper monitor drivers. 3) update your video card settings. Let me know what happens. Good Luck, Tim
Posted on Feb 26, 2007
Yellow lines on pc screen
A quick check would be the VGA cable connection to the back of the PC and monitor. Make sure they are snug and completely connected.
Some monitors have the VGA cable attached as a separate item and not built into the monitor. If the 15pin plug becomes loose it will show the problems you're describing.
If that doesn't fix it, Next plug the monitor into a known good PC. If the problem still exists, you have a bad monitor...If the monitor works fine on the known good PC, the Video Card/Onboard video interface is bad and will need to be replaced.
Nov 29, 2013 | Computers & Internet
Dell 19' flat screen monitor
Check that the graphics card has not become loose in the computer.
Oct 22, 2007 | Dell E173FP 17" LCD Monitor
I got this monitor off of craigslist "because it didn't work". The VGA has never worked, but the DVI worked fine for several months. Recently, the screen goes black, the screen shows a 'no...
Check the VGA output pins on your computer. Install a different monitor and see if it works on your computer. Or it could also be the VGA cable (pins) on the monitor is loose.
Dec 16, 2010 | Neovo E-19A 19" LCD Monitor
My monitor screen has become greenish and with
Hello Devsi, hi, check your VGA cable connection for loose connections, try tighten it first to see if it solves the problem. the greenish thing is cause by a missing red signal, and the distortion is caused by a missing horizontal sync signal, also check out if there are bent pins on your monitor signal cable. just unplug the VGA cable and see if the pins are in order. if bent, carefully straighten it with a slim slotted screw driver.
Dec 17, 2009 | LG Flatron L1750S 17" LCD Monitor
Toshiba Satellite L310, windows xp professional pack 2. My screen is lightly shivering every 4 seconds, even under DOS. During start up, there are black or yellow flashes. Is this a hardware of software...
well if its during startup before windows loads it could be a bad lcd screen or if its during the loadup it could be bad drivers being loaded...make sure drivers for your lcd and adapter are correct ones and most recent
Sep 28, 2009 | Computers & Internet
Monitor turns pink
First I would check the end of the cable that plugs into the computer, if this has become loose, it can cause discoloration. If it isn't loose, unplug the cable and see if any of the pins have become bent on the inside. IF they have become bent, you can usually carefully use a pair of tweezers to slowly bend them straight again (be careful because if you aren't you could break the pin off). If your monitor has the ability to removed the VGA cable from the monitor, you might try replacing the cable (most CRT monitors do not support removing the VGA cable though). Lastly, as this is a CRT monitor, you might need to Degaus the monitor or the electron gun could be coming out of alignment. Most CRT Monitor's have degaus button (usually marked by a symbol of what kind of resembles a horseshoe) which if pressed will degaus the monitor. If your's doesn't have a degaus button, try searching through your menu for the degaus option by hitting the monitors menu button. To see if your electron gun is out of alignment, lightly tap the side of the monitor. If you see the color change, or the color returns to normal, your electron gun is out of alignment and will get worse over time. Buying a new monitor is usually the best option if this is the case.
Jul 31, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My monitor light is on, screen is blank. Monitor has worked for years, suddenly I cannot get anything to show up. Screen is black. I have tried restarting the computer, disconnecting and reconnecting the...
Try another known good monitor. If it works then you know your old monitor has died. If the known good does not work then it could be a graphics card issue. Also check your monitor cable to make sure it is not cracked or any broken pins on either end. Also check to see if cable has possibly come loose on either end. Hope this helps you out.
Jul 18, 2009 | Computers & Internet
Colour defect
check cabling wiggle near connector body. Lost of blue color is what you are describing. Good luck
Apr 18, 2009 | Compaq CV 7500 17" CRT Monitor
Hi my monitors screen becomes yellowish.all colour effected y dis
Do you have a CRT monitor?
Have you tried to adjust the color on the monitor?
How is it connected to your computer?
It sound like one of the guns on you monitor died. But there is some testing you should do first.
If it is a CRT monitor and it is connect your computer properly. First thing to do would be to replace the cable and or try a different monitor that you know works.
To confirm try adjusting the color. If that does not work, if it more purplish it is the green gun, if it is orangish it is the Blue gun. That would be cause by a failed gun or driver.
If the gun is gone it is best to get a new one. It will save you money in the long run.
Thank you...
Jan 27, 2009 | Samsung 793S 17" CRT Monitor
LG Studioworks E700S 17" CRT Monitor Logo
183 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
