I have linux installed on a server in my office andit is password protected.I want to break a password , can i
  • JDTec
    JDTec May 11, 2010
    Trinity Rescue Kit or TRK is a free live Linux distribution that aims specifically at recovery and repair operations on Windows machines, but is equally usable for Linux recovery issues.
    Download and burn a rescue CD on a different computer from this :
    Read the documentation, it works on Linux and windows.
    http://trinityhome.org/Home/index.php?wp...
    Hope this helps
  • Desktopsbyduck-Computers
    Yes passwords can be broken in linux.What is the password for and what are you trying to do??RICHARDM69
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
Yes u can most probably "ROOT" will be the default password.
Posted on Dec 10, 2008
Bought used need to by pass password
You didn't say what OS you are using.
1.To try and remove the password protection you can power off the PC.
remove the side panel and then remove the battery. Leave it for 10 minutes, refit the battery and then power up the PC. The password protection may have been removed.
2. Or at start up, enter the bios settings. You may be able to disable the password from within the settings.
3. If you're not bothered which OS you use, try a new install of XP or Windows 7.
If you don't have XP or Windows 7, ask a friend to download linux and burn it onto a dvd for you(or put it onto a usb flash drive). Put the linux dvd into your dvd drive and restart the computer. You will have the choice of completely erasing Windows, or installing Linux alongside Windows.
Linux is free. It will do everything Windows can do. Linux comes with its own version of 'Office'. The best free versions of Linux are Ubuntu or 'Mint'.
You can download Ubuntu here: http://www.ubuntu.com/download/desktop
Webcams do NOT work in Linux. Apart from that, Linux will do everything Windows can do (but free!) and you won't ever get a virus.
Jan 03, 2014 | Sony Computers & Internet
Tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
Tip
How To Password Protect & Decrypt Microsoft Office 2010 Documents
Microsoft office 2010 , the next big buzz from Microsoft after Windows 7, is a productivity suite for Microsoft Windows,and the successor to Microsoft Office 2007.
Screenshots of Microsoft Office 2010
Not long ago I was just wrote an article about How to Password Protect Microsoft Office 2007 Documents. Now I’ll write a similar article about office 2010 by popular demand.
Microsoft Office 2010 indeed simplified the process to password protect and encrypt office documents. Which was considered a commendable improvement over password protecting documents under Office 2007. as the new process for Office 2010 is consistent across the core Office product line which including Word 2010, Excel 2010, PowerPoint 2010 etc. so here I only need to show you how the process just once using Microsoft Word 2010 as example.
Follow the step-to-step guide To Protect A Word 2010 Document Using Built-in Password Encryption
1. Click the File tab, then Click Info. On the menu to the right Click Protect Document and
Click Encrypt with Password.
2. The Encrypt Document dialog will appear, Type in a password and then Click OK to finish.
Please note – It’s very important to use a STRONG Password or Pass Phrase to protect your word document. Using a long PASS PHRASE (IE:I enjoyed myself today!) however with 10 or more characters will significantly increase the encryption strength of the document and decrease the likelihood someone will be able to break the encryption and gain access to your document.
After setting a password, your document should be protected!
Having password protected your word document? Someone should ask what if I forgot the password. So that’s what I’ll show below.
Follow the step-to-step guide To decrypt Word 2010 Document Using word password recovery 5.0
With this user guide, even a new user can fully control Word Password Recovery 5.0 in less than a minute.
Step1: Click “File>Open” in the Menu or the “Open” button to browse in the Word document.
Select your file in the Open File window, and click “Open“.
Step2: Select “Brute-force Attack (Trying All Possible Combinations)“.
Step3: Click “Start” button in the Menu to initiate the program.
Step4: The program is searching the password. Some time later, a message box pops up to you, displaying the expected password. Click “Remove All Passwords from the File” to remove all passwords (Password to Open and Password to Edit) from the file. Click “OK“.
Following this article, you could password protected your office 2010 and decrypt password protected office 2010 with ease.
on Jun 30, 2010 | Computers & Internet
How can I password protect folders / files on my sandisk cruzer glide 128gb
Use the software that came installed on the drive. Use it to secure the whole disk. To access it you need to enter a password. Be careful though. The drive may not be accessible on Linux or Mac.
Mar 04, 2013 | SanDisk Cruzer Glide 128GB USB 2.0 USB...
Best way of total remote control of office computers, from home? Don't mention teamviewer. Looking for real solution, like windows server, can I have installed windows server on my home computer via...
As long as you aren't using linux on any of the workstations, I would whole-heartedly recommend LogMeIn (www.logmein.com).
It is free and allows you to access any computer on which it is installed through ANY web browser.
Mar 01, 2011 | Computers & Internet
How to download and install linux driver?
Follow the below link to download opensuse latest version http://software.opensuse.org/112/en Please click on the below link for installation guide http://en.opensuse.org/Installation
OR You can get novell suse following the below http://www.novell.com/products/server/howtobuy.html has to be purchased.
May 29, 2010 | Novell SUSE Linux v.10.0 Enterprise Server...
What programming language can i use in linux
you can use c,c++ by default no need to install the extra software like in windows ..
LINUX comes with the softwares just like office suite,programming tools,web designing tools,etc and drivers inbuilt in it ...
so once you install the LINUX you will be having almost all the required softwares inbuilt in it including music player,video player,etc
if you want you can install the extra softwares too but the softwares use in windows doesnt work with linux you must download the separate software for linux ....
linux is best in security wise because no virus will attack to LINUX as the viruses are very less developed as there are scarcity in users of linux and there is no chance of hacking the password in linux like in windows this is because of the greater security used in the linux ....
linux stores the password by making use of shadowing .. so upto this time nobody is unable to hack the password ...
Aug 19, 2008 | Microsoft Windows Server Standard 2003 for...
Redhat es5
This model was found not to be 64bit but 32bit.
May 18, 2008 | HP Compaq ProLiant DL380 G4 Server
Remote access
Yes it is. You can use the vnc server and client utilities for this. Install VNC server on all the linux pcs. Then install the windows version of vnc on the pc you want to connect FROM.
Give the ip address of the linux pc you wish to connect to, and lo, you get the same desktop that is on the linux pc. Of course you can configure password protection.
Another easy but techie way to connect is with telnet or ssh command after enabling these services on the linux pc.
HTH,
Deboo
Feb 16, 2008 | 2wire HomePortal 1800HG Router...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
