FixYa.com
Tags:
Fuji FinePix A500 Digital Camera
A500 Zoom Error
posted by Brettsky on Feb 24, 2007
When I turn on my camera there is a message on the LCD screen saying zoom error. From there the camera will not take any photos though I can still look at photos that are in it's memory. Does it need to be taken to a service centre for repair or is there something I can do myself to reset it?
Thank you.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 27, 2007
FixYa! (100)
advance
Rank:Guru Guru
Rating: 91%, 285 votes
Your lens assembly has become jammed due to impact or contamination.
You can try GENTLY manipulating the extended lens using slight side to side pressure and twisting motions back and forth. Sometimes this will free a component which has jammed out of alignment. Be VERY careful you can easily damage the lens further if you do not use extreme caution. If this method is going to work it will take minimal force to free the components.
If this does not work you will need to find a service center to take the camera apart and re-set the internal components in the proper alignment.
David Millier
Advance Camera Repair
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Digital Cameras problems?
Digital Cameras
My canon mv850i digital...
My canon mv850i digital... Answer This...
Digital Cameras
Strange winding -motor-like...
Strange winding -motor-like... Answer This...
Zoom Error
I've bought a fuji finepix A500... Answer This...
Camera
i own a fujifilm finepix a500.... Answer This...
Won't start up.
Hi, having problems wih my... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
