Question about Kitchen Ranges
Delay firing up - Kitchen Ranges
    Habit-Forming:
  • 171 Answers
Ashes build up nest to the pilot light. the small holes need to be clean. or the oxygen vent it's open a little to much.
Posted on Dec 09, 2008
Wiring diagram for headlight swtch connector 98 Explorer showing wire color coding i.e tan brown, blue orange, black, etc
A chilton book might have it the diagram must be for either non delay/or delay I have some but I'm afraid to give it to you because these although are for fords they might not be the same as yours and could create an electrical fire and I'm not here to destroy your car I will ask some other mechanics for the right ones why do you need this did it fry the connector? ?do you live near s junkyard cut one out and match the wires to that one but make sure it's either delay or non delay it makes a difference
Nov 18, 2016 | 1998 Ford Explorer
Paslode I m 250 only fires after delay
most probably a faulty firing pin, but I recommend you visit the attached link, it worked for me with my sporadic firing Im 250. Fixing Paslode gas framing gun that wont fire or fires intermittently
Nov 11, 2014 | Air Tools & Compressors
Delayed start
Try removing and cleaning the crankshaft sensor. Both sensors are used to determine piston position for the ignition to fire in the cylinders.
Dec 20, 2013 | Dodge Intrepid Cars & Trucks
Need help using the wireless cable release
I assume you're refering to the ML-L3 wireless remote control.
Change the shooting mode on the camera by holding down the shooting mode button and turning the main command dial. You want either delayed remote or quick-response remote. The quick-response remote fires the shutter as soon as you press the button on the remote, the delayed remote gives you two seconds to hide your hand behind your back before the camera fires.
Apr 22, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Why isn't my remote firing my camera?
Do you have the shooting mode set to one of the remote modes? If you don't, the camera will completely ignore the ML-L3 remote.
Press the shooting mode button and turn the command dial to either the Quick-response remote or Delayed remote mode. The Quick-response mode fires the camera as soon as you press the button on the remote. The Delayed mode gives you two seconds to hide the remote behind your back before the camera fires.
Jan 30, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Firing order for a 2002 volvo s60
My apologies for the delayed response...
If you still need the Firing Order:
For the 2.4L:
Firing Order:
1-2-4-5-3
Cylinders:
(Rear of Vehicle)
1-----2------3------4------5
Front of Vehicle
Dec 02, 2009 | 2004 Volvo S60
There's no delay start on our new Miele W3740 washing machine. Can we use an electronic timer in the plug socket to delay the program start (cheap night-time use of electricity)? Thank you. Gerald
yes you could use a delay plug if it dont over rate the plug,,,check how many watts your washer pulls and how many watts the delay plug can handel first,,,if its more than the delay plug can take dont try it or you may just have a fire on your hands,,
even with cheap electricity is it worth that?
Nov 20, 2009 | Washing Machines
COD4 online problems
I would suspect this is caused by your Internet conection speed. Try going wired first, dissable any bacground downloads manually, make sore no other equipment is using internet at the time you're gaming
Have Fun!
Jun 23, 2009 | Sony Playstation 3 (PS3) Console
EOS 30D is slow to fire.
Are you sure you aren't in the delay setting in drive mode? This camera has 2 delay settings, one for 2 seconds between when you press the shutter and when it takes the photo, and one with 10 seconds delay - often used when you want to be in the photo (e.g. self-portrait or group photo).
If you aren't in the delay mode, then I need to know more about your settings. What shooting mode are you using? What type of photo are you trying to take (portrait, landscape, sports)? Are you shooting indoors, outdoors, bright sunlight, overcast, etc.?
Dec 30, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
COD4
Are you playing online? If so how fast is your internet connection. If you are using dial-up, then yes, there is a HUGE time delay and the only way to fix it is to get a faster connection, i.e. DSL or Cable broadband.
-Using a wireless router will also cause timing delays, especially if you have high encryption enabled. I always use a wired connection for gaming with a CAT6 ethernet cable. Good luck.
Mar 15, 2008 | Sony Playstation 3 (PS3) Console
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
