Question about Hitachi 61SDX01B 61" Rear Projection Television
Remove screen from Hitachi Ultravision
I have a spot on the inside screen of Hitachi Ultravision TV. How do I remove the screen to remove spot.
  • Anonymous Dec 10, 2008
    my Hitachi Rear projection TV dose not have a clear screen and I see a picture behind the picture.Cable guy said I needed to clean my mirrow in my tv.how do I getthe screen off from the front, I got the screws our and the speaker front off but how do I get the front screen off dose it snap off like the speaker cover.
  • Hitachi Master
  • 5,138 Answers
Underneath screen remove screws holding screen in place ,it should then slide upward and off.
Posted on Dec 18, 2008
We have a hitachi ultravision model # 50vs810 made in 2005 our problem is when we turn it on the screen seems as if the whole thing should be kinda blue but the corners are kinda black then when we play...
Your TV has a defective optical block which should be replaced by a TV technician only. Due to the cost of the part and labor, it is almost less expensive to replace the TV. The part number for the optical block is UX23751 and is available at the following web site. I hope that helps : )
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/50VS810/Hitachi+Ltd/Hitachi/UX23751/New.aspx
Jul 25, 2011 | Hitachi Televison & Video
My 61" Hitachi UltraVision has
hello my name is rico, you have bad convergence problem. you need to replace the stks inside the tv, and look for colder on the boards. you gonna need a gun solder, solder, chawick, 2 stks(look in the tv for the number loooks like stk392-120 o something like it) look for bad fuses. that should fix your problem. if you need more help let me know at 602-810-7149.
Jan 07, 2011 | Hitachi 61SDX01B 61" Rear Projection...
Hi! my tv hitachi 50v500a ultravision had problem the screen of the tv have big red cloud
There is no solution - eventually the entire picture will turn blue. It's out of warranty and replacement of the light engine is way too expensive. Start shopping for another tv - I did
Dec 24, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
I have a spot in the middle of the screen that red shows up as almost black. It looks like the old problems when magnets were put on the old fashioned TV's It is a 50 inch Hitachi Ultravision. I replaced...
That is going to be a failure of the light engine itself. The part number for that is UX25302R. The part is not a user replaceable part due to the complexity to remove and reinstall the new one. Here is a link for the part and to purchase it as it runs 521 dollars. Please take a few moments to rate my answer. Thanks...
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/UX25302R/New.aspx
Nov 16, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 42" Ultravision TV, and suddenly every thing has gone green, and the reds have gone. I've rebooted the cable system a few times, and it's still green. My other TV is fine, so I'm guessing...
don't run it like that suspect shorted crt or video output try adjusting the screen control for the specific color if no change then it is as mentioned put screen control back to the starting spot.
Oct 07, 2008 | Hitachi Televison & Video
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision
NEED TO CHECK the convergence ICs "stk _ _ _" , also check for some burnt spot (dry solder) around the power supply,
hope this helps AJ
May 12, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision dlp projection tv
No you need a light engine, possibly covered under a recall, other wise its like your cars block is cracked
Apr 28, 2008 | Televison & Video
Hitachi 61SDX01B 61" Rear Projection Television Logo
729 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
