Question about Akai LCT3201TD 32 in. LCD Television
TV turns itself off
When you turn the tv on the indicator light turns green, and stays green for a couple seconds, then turns red again. So it doesnt allow the TV to fully turn on. It will do this continually. Occasionally you can unplug the tv, plug it back in, then it will turn on. But sometimes that doesnt work.
  • manitcrazy Dec 25, 2008
    when you trun tv on the indicator turns green and stay green for a couple seconds and turn red again occasionally you can unplug the tv plug it back then turn on sometimes that doesnt wrok
  • 2,326 Answers
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to
Posted on Dec 09, 2008
Brought a second hand ps3 slim 160gb.when everything is on tv says no signal i hold button down but no beeps light goes from green to red anybody help please
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Akai LCT3201TD 32 in. LCD Television Logo
219 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
