Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
Standby blinks seven times
Need to check power supply regulation and horizontal circuits, how do i go about this
    Genius:
  • Sony Master
  • 1,667 Answers
There are many details involved to check the set. The process is beyond the practicality of an email.
You will need the service manual, a DVM, and depending on the circumstances you will need a scope.
The service manual may still be available from Sony.
Most of the time in these models of set, this type of fault is a failure in the scan amplifier sections; mainly in the horizontal output section. If this is the case, there may also be some damage in the power supply.
Jerry G.
Posted on Jan 09, 2009
Sony trinitron standby light blinks 7 times. no picture. light continues to flash. tried hard reset. no picture. model sony wega kv-36hs510.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Televison & Video
Sony trinitron kd-34xs955 standby light is blinking 7 times
As you can see here, seven blinks of standby light is due to some over voltate at the final anode of the picture tube. This is a protection process that going on insde the tV circuits, to prevent more damage to other comnponents on board. The most common cause for this is with the main power regulator out voltage itself. If any way, it ahs exceeded 135VDC, this kind of fault will occur. Check the main power regulator section circuit for any damaged component/s. Replace all the small electrolytic capacitors there. Visit the site named 'Electro-help' for more details. Check this LINK and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 550 posts to different brand TVs. Blinking codes and details are there.
Aug 09, 2012 | Sony FD Trinitron KD-34XS955 34" TV
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
I was watching the news and it shut off on its own and will not turn back on. What do i need to check?
If you include how many times the standby light flashes, that will give a fault location. Not to worry, here is a list.
Hope this helps.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Jan 23, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
The tv standby light blinks 7 times then repeats. What do I do?
Dear John,
Welcome to Fixya
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. I think it helps
Chandrashekhar
Dec 27, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have a Sony kv-40xbr800. The standby light flashes 6-7 times and does not turn on. If left off for a couple of day, it may turn on. Is there an easy fix?
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
Jun 05, 2010 | Televison & Video
Standby blight bliks for seven time tv wont turn on
Seven blink indicates that there is a high voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Hopw this helps .
Jan 23, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony TV will not turn on. The standby light flashes 7 times. Whats wrong?
Seven blink indicates high voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Also it can be due to bad flyback.
Hope this helps.
Thanks for using Fixya.
Dec 08, 2009 | Sony Televison & Video
The standby botton blink 7 in my sony trinitron
May 07, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony wega tv blinks seven times and does not come on
seven blinks means high voltage shutdown it gone into safety mode you need to check power supply regulation and horizontal circuits
shaun
Jan 16, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
130 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
