Question about Husqvarna Chain Saw 20" Bar
Husqvartna Gas Vent
My husqvarna would die when i pressed the throttle so I ran it with the gas cap off and it worked fine.  I think that the vent is clogged but I don't know where the vent is located (doesn't seem to be in cap).  Any suggestions?
Most husqy gas tank vents are on the same side of the tank right where the fuel lines enter the tank.
Posted on Mar 01, 2009
  • 211 Answers
Hi
First check the fuel filter ,inside of the gas tank:After that, try to find out where is the airating sistem(gas tank vent):For example a hose with a sprig into it,or any other sistem. Check it.
best regards savumihai71
Posted on Dec 10, 2008
Stops running then will not restart
need more info. It sounds like it does run or you would have stated it stopped working and will not work anymore. I need more info please.
When it stops is it because you gave it the throttle and it quit or does it just up and die as if it ran out of gas in which case it will sputter first or does it run then instantly start to stop then instantly run again. What I can do at this point is give you somewhere to start. Number one the on off switch can be faulty and will cause it to start to instantly die and then immediately run again and also maybe go dit-dit-dit-dit while running like it was skipping or sputtering. How old is this saw? Inside the fuel tank is a filter. If you take a flashlight you will see it. reach in with something and pull it out with the hose. be careful not to damage the hose. Remove and replace the filter. If it runs good til it gets hot and if you loosen the gas cap it takes off running again, replace the gas cap as the vent hole is plugged. So if can reply back with more info.
Nov 04, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Starts fine, run fine,for about 2 to 5 min.,then cuts off,sounds like it's not getting the gas.
I have a Husqvarna 125B same problem. Turned out to be a bad gas cap. Doesn't vent properly and starves the engine. I took the gas cap off of my Huqvarna weed eater and put on blower and blower worked fine,
Nov 11, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Can get gas to motor changed filter
try and run it with the gas cap loose there is a vent in the cap that can get plugged up (think of putting your finger on the top of a straw)
Aug 31, 2012 | Husqvarna Garden
When saw is running it dies unless i undo the vented gas cap then the saw will keep going is there any other way on other than the gas cap for it to vent or help breath? on a 372 xp
The vent on the 372 is not in the cat, it is situated on the right hand rear side of the fuel tank, the early vent was a black pipe pressed into the tank with a white ( vion ) plug in it, this can be pulled out by screwing a self tapping screw into the middle of it and pulling out with a pair of pliers, the later breather is in the same place but consist of a green valve pressed into the tank, it then has a black pipe conected to it which comes up into the crankcase and sits onto a nipple under the air filter, this can be pulled out with a pair of pliers and replaced, the later breather is very prone to blocking, due to CE law and gas escape from fuel tanks the breather is very fine.
Jan 25, 2011 | Husqvarna Operator's Manual 365 372xp ...
Stihl MS290 only runs if the gas tank vent valve is removed, then it runs. also when after cutting a full throttle upon release chain saw does not recover to an idle but dies. Have put in new carb. and new...
sounds like you have a plugged vent either in the gas cap or the vent valve of which you speak. Without the vent working properly, the engine running and drawing gas from the fuel tank causes a vaccum inside the tank making it harder for the fuel to draw to the carburator. this would cause the symptoms that you are talking about.
Replace the gas cap if it is vented or check to see if the vent valve you mention is working properly.
Good Luck
Dec 21, 2009 | Garden
Wont run for long
Without know the model number, I couldn't say. You could go to.. http://www.partstree.com/parts/ click on Husqvarna, then enter the model number on the left. That will bring up the diagram for it. It may have a duckbill valve inside the cap or an external vent elsewhere.
Jul 01, 2009 | Husqvarna 28cc Gas Line Trimmer
My ryobi will start but dies about 5 minutes later
Try running the machine with the gas cap loose. There could be pressure builiding up in the system due to the cap being too tight. There is no vent on these systems like an automobile. If the gas cap is overtightened this could be your problem as the cap is equipped with a gasket that allows the vapor to vent through the cap. Overtightening could be sealing off your vent
Jun 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Husqvarna Chain Saw 20" Bar Logo
1,211 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
