Question about GE Refrigerators
Model GSL25IGRBBS - freezer circulating fan needs replaced
I have the replacement fan and was able to get at the fan in the freezer section. However, when I unhooked the harness, there were 2 extra wires in the harness in the freezer that came form somewhere else. The wires from the replacement motor match the existing motor and the harness is the same except for the 2 other wires (white). Where do they come form and how do I change out the motor and get the correct wiring?
5 Suggested Answers
  • 4 Answers
SOURCE: maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
Posted on Jul 10, 2008
rpbuice
  • 161 Answers
SOURCE: refrig & freezer not cold enough; ice forming; low air volume
If ice/frost is building up on the back wall of the freezer then you have a defrost system failure.
Defrost system; Evap Fan, Heater, Thermo disk, Timer.
Evap Fan - this should be running all the time except when it goes into defrost mode.
Defrost Timer - This part is hard to locate on some models, a call to a parts place with the model number can help you find it and tell you if this is the type you can mannualy turn to put in the defrost mode. If you can do this, take the back panel off in the freezer so you can see the cooling coils. The heater should be red hot and melting the ice. If so, replace the timer. If not, you need an OHM meter to check the heater and therma disk.
Un plug the Ref, locate the heater, usually looks like a heating element in an oven and runs across the bottom of the coils. Touch the meter leads to each end of the heater. If no reading, replace.
Therma Disk - located close to where the coils enter the freezer, small round disk clipped to the coils. Check the same as the heater but, you won't get a good reading unless the temp is below freezing. Any doubt, just replace, it's not that expensive.
This is a lot to do, hope this helps.
Posted on Jan 23, 2009
  • 27 Answers
SOURCE: kenmore fridge start relay wiring
there is no need to shroten the lengths of the wires, u can directly connect it
Posted on Mar 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
Posted on May 25, 2009
SOURCE: My GE side-by-side howls. Model GSL25IGRBBS.
First of all - make sure you route the green grounding wire connector from the board to one of the screws, holding the board cover. If you leave it hanging - you can kill the board if the wire touches some of the board elements.
Second - check what kind of sensors you have in your fridge. There are three of them: one in the fresh food section, and 2 in the freezer.
If any of the sensors has black compound where the wires enter the white plastic cylinder, you'll need to replace it with the newer one: WR55X10025
Locations: One behind the damper cover in fresh food section (far left top corner)
One in the far left bottom corner (small cover with 2 white wires to it)
One (which most likely makes the problem) is on top of the evaporator (coil in freezer section, behind the lower back cover). Ifyou replace any of them - make sure to insulate the splice points with food-grade silicone.
Posted on Oct 16, 2009
Testimonial: "You truly are my guru. I don't know how you knew exactly what to look for, but the thermosters were just as you described. Thank you, it works!"
Kenmore refrigerator(model 10653606202) freezer is cooling, can hear the circulation fan' noise, also see defrosted water in the bottom collection pan. but the refrege is not cooling.
If the freezers is freezing everything and you can hear the circulation fan, maybe it is a defrost problem. Sometime ice will build up behind the rear panel in the freezer section that blocks either the chilling tubes to the refrigerator section.
You will need to remove the food from the freezer, then remove the shelves and inside back panel of the freezer. If you see a lot of ice, that is probably your problem. DON'T use water to defrost, either unplug and let it set with the door open or hurry it up with a hair dryer.
It also means your defrost assembly has stopped working and will need replaced, but the unit will work without it for several weeks before the ice build up redevelops.
Jun 07, 2011 | Refrigerators
Hey there, I have a Westpoint NOFROST De Luxe Tropical frige, model # WRK 297.1. The freezer section is forming ice and the circulation fan is making alot of noise due to ice being formed behind the back...
I believe your problem is the defroster circuit . There are only three components on most refrigerators unless you have something real special . Kidding . They are as follows : defrost timer , heating element , and defrost cut out switch . The defrost timer cycles the refrigerator out of normal operation and into defrost mode once every six to eight hours depending on the unit . When in this mode everything shuts off , compressor , circulation fan , and condenser fan is so equipped . To eliminate the circulation fan , you'll have to keep an eye on your refrigerator checking in every half hour or so for six hours to eight hours and see if it stops working . If it does , then we know the timer is working correctly and the problem will be the heating element or cutout switch . The heating element is checked with an ohm meter. Usually they burn out when they go bad and you will read infinite resistance. The defrost cutout switch should read 0-1 ohms when the freezer temperature is 40° F or lower. If the heating element checks good , in other words it shows to have resistance usually between 30 and 100 ohms, replace the cutout switch . If the circulation fan never shuts off and the unit continues to run without shutting down after a six or eight hour Time cycle , replace the defrost timer . Good luck
Feb 22, 2011 | Refrigerators
I have a Frigidaire top freezer refrigerator which stopped cooling the lower section while the top section stays frozen. I can hear it run through it's cycle but no freezer fan comes on. What would cause...
the evaporator fan is not spinning. the coil is getting too cold because the fan is not circulating the air across it. defrost it and see if the fan works. If not, they are fairly inexpensive and easy to replace. There is an access cover on the back wall of the freezer. remove it, and the fan is right behind it.
Nov 20, 2010 | Frigidaire FRT21H8C Top Freezer...
Model: GSH22JFT (GE side by side) freezer working by refrigerator not cooling.
The most common problem for your model refrig , to stop cooling the ref section , is a shorted defrost heater in the freezer section . Do you see a light layer of frost on the rear inside lower freezer wall ? Do you hear the fan in the freezer working ? If you have the frost , you will need to remove the rear inside freezer panel ( 2 screws ) , and at the bottom of the coils , is the defrost heater . Part number WR51X10101 . This replacement heater , comes with 2 heaters , due to the old 1 heater burning out so often . The part , sometimes comes with a wire extension , since the blue wire will have to be moved over to the right , with the orange wire , to make it long enough to fit , and sometimes doesn't come with the extension , in which case , you will have to make one . It's also best , to replace the defrost thermostat ( bimetel ) while the panel is off also . Part number WR50X10068 .
Oct 25, 2009 | GE GSH22JFTSS Stainless Steel Side by Side...
Oct 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer portion works but not the refrigerator section
sounds like the freezer/refrigerator circulating fan is wearing out, when this happens the rpms are reduced to a point that fan does not circulate enough air to the freezer and the refrigerator. The minimum cost to replace the fan assembly is around $300.00
Jul 11, 2009 | Refrigerators
The fridge section is warm, the freezer is OK
sounds like the circulating fan is wearing out. This fan supplies circulation for the freezer as well as the refrigerator when the motor for this fan starts to wear out the circulation supplied is reduced to a point that the freezer will work but not the refrigerator because the fan does nnot run fast enough to circulate the air thru the refrigerator. The minimum cost to repair/replace this fan assemble is around $300.00
Zanussi zx99/5 freezer working fine but my fridge is too warm
This may be an airflow problem. These are things to check. Make sure the temp control in the fresh food section for both the freezer and the fresh food is set half way between coldest and warmest temp setting. Over adjusting these settings can cause poor air circulation and make the fresh food section too warm. When openning the freezer, the evaporator fan should be on or start shortly. If the evaporator fan stops working, there will be no circulation to cool the fresh food section and will need to be checked to see if it is bad. If bad it will need to be replaced. The evaporator in the freezer section may be iced over causing poor air flow to the fresh food section. You may need a service tech to check this part. If the evaporator is iced over, stopping air circulation, the button thermostat or defrost element may on the evaporator may be bad and could possibly reqiure a technician to replace it Check the first two things and let me know what you find and how it is doing after reseting the temp control. I will be happy to help you in any way I can..
Nov 10, 2008 | Zanussi Refrigerators
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
