Question about Coby DVD-218 DVD Player
Loading ... then no disk
Whenever a DVD disk MP3 cd is inserted, that's the message I get: Loading ..., then 'no disk. Tried cleaning, but this did not help. Tried unplugging and wait overnight then try again, this didn't work. Tried adjusting the variable resistors on the lens assembly, nothing! My other suspicion is the motor that spins the disk itself, it seems to be going a bit slower. Maybe there is circuit component(s) that broke down or the motor may be bad. If there is a solution or confirmation, please let me know.
    Top Expert:
  • Coby Master
  • 76,036 Answers
Laser pickup unit fault [weak]. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on May 19, 2017
SOURCE:
  • 10 Answers
SOURCE: wrong disk problem
Then lens may need a damp isopropyl alcohol qtip run over it a few times, use 90%. If that doesnt work then try a cd cleaning disk to put in the player. The cd or dvd may also be too scratched to read.
Posted on Feb 12, 2007
snakehead
  • 1074 Answers
SOURCE: Devise reads no disc when disc is inserted
there is a flat white strip that is connected to the body of the lens replace it if that does not remedy the problem replace the lens.good luck
Posted on Apr 19, 2007
SOURCE: NO DISK error
where would you buy the CHANGE STRIP WIRE TO THE LENCE
Posted on Jun 22, 2008
  • 905 Answers
SOURCE: disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Posted on Jan 15, 2009
stonephoenix
  • 563 Answers
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 05, 2009
Cd says loading error and wont play
disks re lazer screen needs cleaning disk cleaner
Aug 12, 2012 | Alpine IVA-D100 6.5" Wide LCD w/DVD/CD/MP3...
HI when i put disk in cd rom drive the computer only reads for about 3 seconds and then the message says insert a disk..my son has been burning a lot of disks lateluy and not sure why it broke so soon,only...
Loading new device-drivers will not help.
In the first few seconds, the drive is trying to read the first few blocks of data from the media, to see if it is a "data" or "music" or "blank" CD. If nothing can be read (dead laser?) then you get the "insert a disk" message.
> do I need a new unit?
Yes; spend $40 to buy a new CD/DVD reader/writer.
Oct 11, 2010 | HP Computers & Internet
Alana cd/mp3 radio doesn't read mp3 cds
I have the same problem with my ibiza. Existing a solution ? This alana radio can read mp3 disk ? Thank you
Mar 01, 2010 | Car Audio & Video
Recently, i;ve been trying to record tv programs on my Panasonic DVD Video Recorder DMR-E50, as i have done so for many years. However, lately, whenever i program it to record a tv program using the timer...
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Mike
Aug 17, 2009 | Panasonic DMR-E50 DVD Recorder
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
D1817PKG DVD. Turn on unit - insert cd movie- audiovox loading - does not recognize cd
My dvd player tries to load dvd, then says Cannot Read Disk. Have tried different disks.
Jun 13, 2008 | Televison & Video
Loading error
dvd error disic after playing ten min, the pitcher crash
May 04, 2007 | Alpine IVA-D300 Car DVD Player
"loading" then "no disk"
You might as well just replace the player, the cost to repair is more than a new one.
May 18, 2017 | Coby DVD-218 DVD Player
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
Coby DVD-218 DVD Player Logo
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
