I need to factory reset a Siemens AP2620
I think I stuck a couple AP's in a non-working Vlan.
I can no longer ping the AP's.
If I can reset them to factory defaults though, I can get the system back up in no time.
Is this possible? My Siemens rep is on vacation right now.
  • Anonymous Dec 31, 2008
    i want telnet password
  • 62 Answers
If there is no tiny push button on the outside of the box then the only way to reset it is loging into it.
If you can find the ipddress range of the non-working vlan that the AP is in you can change your computer ip address to one in that range and then access the router with it's ipaddress.
Once you get in you can use these steps to reset it:
a. Click the Wireless Controller button to open the Wireless Controller
Configuration screen.
b. In the navigation pane, click System Maintenance.
c. Click the Reset database to factory default and reboot button.
d. Click the Apply button.
This will reset the database and cause the controller to reboot.
Regards
Posted on Dec 20, 2008
What Are the Differences in AP-side Switch Interface Configuration and Intermediate Switch Configuration in Direct and Tunnel Forwarding Modes?
Differences in configuration on switch interfaces connected to APs are as follows:
In tunnel forwarding mode, interfaces connected to APs transparently transmit only packets of the management VLAN. These interfaces must be added to the management VLAN in untagged mode. In direct forwarding mode, interfaces connected to APs must be trunk or hybrid interfaces. These interfaces must be added to the management VLAN in untagged mode and added to service VLANs in tagged mode. If a trunk interface is connected to an AP, the PVID of the interface must be set to the management VLAN ID.
Differences in configuration on intermediate switches are as follows:
In tunnel forwarding mode, intermediate switches transparently transmit only packets of the management VLAN. In direct forwarding mode, intermediate switches transparently transmit packets of both the management VLAN and service VLANs.
S5700 Switch Thunder link com
Oct 17, 2016 | The Office Equipment & Supplies
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
I have two linksys srw2008 switches connected together I can administer both but the new addition(Second) won't pass traffic back - IE I can connect one device to the first one and recieve pings back but...
Please try to make the port where you are connecting you PC as untagged port under VLAN 44 and make the ports connecting the switch to the other one as Tagged port.
Dec 04, 2010 | Linksys SRW2008
How can I change the default management vlan (vlan 1) to another vlan # in Cisco Aironet 1242G wireless AP
create a new vlan (eg vlan 10)
then ensure that the ethernet port is the same bridge group number as the new vlan (bridge-group 10)
do the same for the wireless port
then shut down vlan 1
Oct 06, 2009 | Cisco Aironet 1242ag 802.11a/b/g Wireless...
No internet linksys connected to catalyst 2900 XL
check the vlan settings of the port on the switch to where the AP is connected, and check the vlan of the AP
Sep 13, 2009 | Cisco Catalyst 2908 (WS-C2908-XL)...
Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Feb 01, 2009 | Cisco Catalyst 3750E-48PD
Router no connecting to the internet
You need to configure NAT on the router to permit the entire LAN to access internet
Example.
LAN Segnment is 192.168.1.0/24
1. Create an access-list to identify the local segment
2. Configure the Nat interfaces properly (NAT-INSIDE, NAT-OUTSIDE)
3. do the NAT configuration
i.e ip nat inside source list (ACLNUMBER) .....
Dec 08, 2008 | Computers & Internet
System pin # reset
There is a way to override and reset... I think you need to press *67# when in the system pin area via menu. Confirm this first though. There is a way to do this though- then you reset it to 0000- google it and you will find the answer-
Dec 01, 2008 | Siemens Gigaset 2420 Phone
How to probe the configuration or reset the 2700AP?
Restore it to default, with these things, if it wont work on automatic, then something is worng.
Feb 27, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
Loses connectivity
Hi, a couple of ideas: 1. maybe out of range or too many obstruction, how far is the client from the AP or are there any objects in between. it's gotta be line of sight; 2. with 200mW power output and 5dBi external antenna, should be adequate, if not maybe slightly directional performance (no longer perfect omni). try rotating the device and more or less guesstimate max signal at a particular orientation (pointed towards the client). Netstumbler would be good enough for signal strength; 3. consider the optional integrated 9dBi patch antenna; 4. for the client having a hard time with the AP, manually enter the TCP/IP settings and not auto obtain. numbers should of course match AP settings except for the last digit(s) of the IP add; 5. try moving the client away from any RFI sources like cordless/wireless phones, microwave ovens and others; 6. at one time, signal strength to a client improved by moving the AP a couple of feet away from the original installation point. of course if your unit is mast mounted, then you have to move the mast as well or put up a new one. Hope this works for you. Good luck and pls post again how things turn up.
May 24, 2007 | EnGenius EL-2611CB5+ (NL2611CB5)
Computers & Internet Logo
1,931 people viewed this question
David Payne
David Payne
