Question about Samsung ML2250 Laser Printer
Samsung ML2250 will not print WINDOW documents but prints emails
Unit is 25 months in age. This is first time the problem has occurred. ON LINE / ERROR red light comes on. Unit will print e-mails. It will print a Windows document if I cut unit off then cut back on, but only one item per print command. I have re-booted my PC 2 times, checked all connections, no solution. This is a home use unit, I print about 2500 copies per year.
  • Samsung Master
  • 4,806 Answers
The printers software and drivers have become degraded overtime, all you have to do is remove power from the printer, go to the pc and unistall the printers software, restart the pc and reinstall the software (power up the printer at the same time without the USB connected)
the sofware may ask you to plug in the USB during intallation.
When the software has installed realign the cartridges and print a test page, this should resolve your problem
kind regards
Posted on Dec 08, 2008
    Sergeant:
  • 399 Answers
Check out or any paper jam first in the device.if its clear.then just uninstall the printer driver and reinstall it again.to solve the problem.
  • 599 Answers
Recheck connections and shut windows down completely for 5 minutes before rebooting.... then if it still doesnt see it.. go to samsung site and download latest drivers and uninstall/reinstall with new...good luck
    Genius:
  • 1,199 Answers
Try reinstalling the software!
I have a samsung ml-2250 that when it begin to print, it print just somthing like html scripts til the paperes finish. what can I do for it?
Dear
Its the problem with the OS or its application try to reinstall. Its not the problem of printer.
Thanks.
Jun 17, 2012 | Samsung ML2250 Laser Printer
My Samsung ML-2250 printer sounds like it's starting to print a page but then it just stops and the red light comes on.
Hi ,
kindly Open His Cartage Cover , And try to have a look in Imagining Unit , I think Its not fixed Properly.
Shahzad Rashid IT Hardware/Software Engineer
Feb 17, 2011 | Samsung ML2250 Laser Printer
The printer is printing dark vertical line on the
90% or more of the time on this printer dark lines are coming from your toner/drum cartridge. You can verify this by changing cartridges if you have a spare. If you don't then remove the cartridge and look at the colored cylinder in the cartridge and see if the same "lines" are on the cylinder that are on your prints. This will tell you for sure that the cartridge is bad.
Dec 13, 2009 | Samsung ML2250 Laser Printer
Samsung ml-1710 printer does not always print
you need to reinstall printer with samsung printer driver specific for this model that can be downloaded from samsung website
Oct 04, 2009 | Samsung ML 1710 Laser Printer
Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Jul 19, 2009 | HP Office Equipment & Supplies
On Line / Error Red light comes on.
recheck connections and shut windows down completely for 5 minutes before rebooting.... then if it still doesnt see it.. go to samsung site and download latest drivers and uninstall/reinstall with new...good luck
Dec 08, 2008 | Samsung ML2250 Laser Printer
Line down the middle
The drum cleanig blade of your Samsung has unfortunate a crack (or a scrape) in the middle and in that place it does not clean the drum between rotations, so there you'll have toner powder remaining from all the letters in the middle that where not cleaned from the drum.
So, you should replace the drum cleanig blade or ask a professionist to do it.
Replace the drum as well, if you are there, it's better to give a new drum to a new blade.
Rate the answer and et me know if this was helpfull!
Feb 13, 2008 | Samsung ML2250 Laser Printer
Samsung ML2250 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
